Removing the engine vs damage
Old Apr 17, 2008 | 08:55 AM
cajos's Avatar
cajos
Default Removing the engine vs damage
I'm interested to know how often you have removed the engine and damaged the car / chipped the paint?
Old Apr 17, 2008 | 09:51 AM
BenUK's Avatar
BenUK
Removed: once.
Damaged: never.
Old Apr 17, 2008 | 11:09 AM
Gordonm's Avatar
Gordonm
I have had mine out 3 times with no damage to anything. I even leave the hood on.
Old Apr 17, 2008 | 11:49 AM
PhyscoVette's Avatar
PhyscoVette
I have pulled the engine and trans together twice with no damage
Old Apr 17, 2008 | 01:29 PM
cajos's Avatar
cajos
Any tips, tricks and advice?
Old Apr 17, 2008 | 01:31 PM
fauxrs2's Avatar
fauxrs2
3 times, engine tranny connected, not a scratch
Old Apr 17, 2008 | 01:35 PM
Muddywaters's Avatar
Muddywaters
Slowly and carefully!!! Removed mine for the restore..no chips or damage. Re-installed the same way! I did have my hood off...Muddy
Old Apr 17, 2008 | 01:58 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
i think ive done 6 or 7 swaps and no damage at all
Old Apr 17, 2008 | 02:01 PM
garage-ghost's Avatar
garage-ghost
A a a a a that would be Never......and another Never..
Old Apr 17, 2008 | 02:04 PM
7T1vette's Avatar
7T1vette
Use lots of protective pads (blankets?), etc. on the areas likely to get hit. Maybe even put some corrugated cardboard on top of the pads; a swinging engine can really do some damage if it gets out of control. Use some kind of "tilt" adjuster gizmo on the lift so that you can easily tilt the engine as you need [experienced mechanics know how they want it when they start and don't really need one].
Old Apr 17, 2008 | 02:07 PM
SIXFOOTER's Avatar
SIXFOOTER
Use a good long arm cherry picker and short chains on a tilt plate and take your time, cover the fenders with moving blanket. Go Slow and you should have no problem at all, there should be NO reason for the engine to be swinging. I have done several and never a problem
Old Apr 17, 2008 | 02:21 PM
Tecdiverfl's Avatar
Tecdiverfl
Sixfooter and I pulled my motor with trans attached. We took the hood off and had no problem. As He said use some blankets and take your time. We hooked up the hoist from the side of the car and pulled the motor and trans out. If you want some pics let me know.
Old Apr 17, 2008 | 02:29 PM
Corz's Avatar
Corz
wuss
Old Apr 17, 2008 | 03:44 PM
cajos's Avatar
cajos
Tecdiverfl: If you have pic's please share them.
SIXFOOTER: cherry picker. A what? We are talking engines, don't we?
Old Apr 17, 2008 | 04:00 PM
mdj21's Avatar
mdj21
cherry picker.....
http://www.harborfreight.com/cpi/cta...emnumber=46766
Old Apr 17, 2008 | 04:04 PM
cajos's Avatar
cajos
Ahh I see, I have 2 of those in my workshop
Old Apr 17, 2008 | 05:51 PM
Alan 71's Avatar
Alan 71
7T1 is right.The MORE time you spend padding and protecting the LESS time you spend painting.
Regards,
Alan
To Removing the engine vs damage
Old Apr 17, 2008 | 06:09 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
Just like Tecdiverfl: protect well, I removed hood, radiator, LF tire, captured, tilted, and removed with trans mounted. Disconnected trans once cleared from body.
[IMG][/IMG]
I've read that some dudes leave rad in but mine's being replaced with a new Dewitts. My picker is old Lakewood unit from the early '80s so boom is fixed. Harbor Freight units are adjustable boom length, affordable, and fold up when not used.
Old Apr 17, 2008 | 08:07 PM
AirTrafficController's Avatar
Piece of cake. Take your time...
Old Apr 17, 2008 | 10:42 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
Be careful do it yourself, you always baby your own better than anyone else
