What a pain in the a**
Old Apr 29, 2008 | 09:37 PM
cargo247's Avatar
cargo247
Default What a pain in the a**
Replaced the seal for the shift arm on 81 auto transmission with little room to work ripped knuckles and just when I thought it was seated….. ripped it! ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hhhhhhhhhhhhhhhhhhh I think I will drink now!
Is there an easy way to remove this seal????
Todd
Now I will drink!
Old Apr 30, 2008 | 12:24 AM
AzMotorhead's Avatar
AzMotorhead
Limping across the line
with the Snap-On tool
Old Apr 30, 2008 | 07:48 PM
cargo247's Avatar
cargo247
Thanks...
Old Apr 30, 2008 | 08:31 PM
SIXFOOTER's Avatar
SIXFOOTER
Removing it is easy, drop the pan, remove the shift arm and shaft and pop it out with a screwdriver.
Getting it back in can be a challenge. You might be able to get on it with a short socket and tap it in with a hammer.
Worst case, drop the x-member and ease the back of the tranny so you can get a better angle on it. Watch the distributor cap on the firewall.
Old May 7, 2008 | 01:01 PM
AzMotorhead
Sorry mang you asked
Old May 7, 2008 | 03:53 PM
7T1vette's Avatar
7T1vette
[as mentioned above] Small flat-blade screwdriver...poke tip through the rubber seal and under the casing, push down on handle to pop it out. Don't damage the shift shaft surface.
To What a pain in the a**
