It's alive
Old May 7, 2008 | 02:32 PM
V-Twin's Avatar
V-Twin
Originally Posted by lars
You can attach the spring in one of two ways: You can attach it to the top of the throttle lever and have it pull forward, or you can attach it to the bottom of the lever and have it pull back. Most factory setups use the latter. However, when both the spring and the throttle cable are exerting force on the throttle shaft in the same direction (back), you tend to wear the throttle shaft bushing from this constant rearward pull on the lever and shaft. If you're not concerned about a correct stock setup, you can install the spring on the top pulling forward, and this force offsets, somewhat, the rearward pull of the cable. This reduces wear on the throttle shaft bushing. Also, if your throttle shaft already has some wear and the carb does not return to a constant idle speed, you can do the top-forward spring mounting to solve the problem without installing a shaft bushing.
Lars
Thanks, that confirms what I thought!
Old May 7, 2008 | 02:33 PM
V-Twin's Avatar
V-Twin
Originally Posted by Mia
Call me ignorant, but what happened to your rear leaf spring?
Aldan eagle coil overs
Old May 7, 2008 | 02:47 PM
rays71's Avatar
rays71
NICE !! any pics of the mopar ?
Old May 7, 2008 | 03:11 PM
V-Twin's Avatar
V-Twin
Old May 7, 2008 | 03:52 PM
rays71's Avatar
rays71
Very NICE !! only needs a pair of scoops on the hood (superbee)
Old May 7, 2008 | 04:02 PM
V-Twin's Avatar
V-Twin
Like this?
or this
