Got my crate engine today
Old May 17, 2008 | 06:06 PM
den(thevetteman)78's Avatar
den(thevetteman)78
Default Got my crate engine today
I just got my crate engine 350/ 290 HP from GM performance parts. Feel like christmas.
Old May 17, 2008 | 06:20 PM
Durango_Boy's Avatar
Durango_Boy
That's really cool.
Old May 17, 2008 | 06:29 PM
den(thevetteman)78
I will pull out the old one tomorow and will detail the engine bay before dropping the new one in. Those ugly valve cover will be replace by my polish aluminium L82 cover.
I just don't know how i should pull the old one. The cherry picker in front or on the side. I will pull out the transmission as well.
Old May 17, 2008 | 06:34 PM
Binnie77's Avatar
Binnie77
Dennis, I pulled my over and out the side. I just straddled the driver side wheel on an angle with the picker. You have a fun project ahead of you, just wish I lived closer to give you a hand.
Old May 17, 2008 | 06:42 PM
den(thevetteman)78
Originally Posted by Binnie77
Dennis, I pulled my over the side out the side. I just straddled the driver side wheel on an angle with the picker. You have a fun project ahead of you, just wish I lived closer to give you a hand.
It's my first time i change a engine so i might need some advise when time come to drop it in. Like things that i should do before starting it.
Old May 17, 2008 | 07:14 PM
Binnie77's Avatar
Binnie77
Dennis, I have an oil priming tool if you need one. I can shoot it in the mail to you in short order. I bought it from Summitt when I was installing my ZZ4.
Old May 17, 2008 | 08:33 PM
Alan 71's Avatar
Alan 71
Dennis,
You must have been a VERY good boy for Santa to bring you that NICE a present!!!! Good luck putting it in!!!!
Regards,
Alan
Old May 17, 2008 | 09:59 PM
marshrat99's Avatar
marshrat99
Sweet.
Old May 17, 2008 | 10:21 PM
den(thevetteman)78
Originally Posted by Alan 71
Dennis,
Regards,
Alan
I did a lot of overtime just to buy this. Every penny a made from overtime went for that engine. All those long evening spend at work seems like nothing when i look at my new gift. To me, From me.
Old May 17, 2008 | 10:44 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Congrats
I just fired up my GMPP crate motor for the first time today.
I could not use my cherry picker from the front. Extended out all the way, the boom wasn't long enough. I removed the left tire and went in from that side. It worked fine.
Hope you get it going soon.
Old May 18, 2008 | 01:27 AM
Kellys~hotrods's Avatar
Kellys~hotrods
Very Nice! I have the long block versoin (less manifold, carb, filter, and exhaust) in my 1978 stepside. I'm running a tuned edelbrock 600, edelbrock performer manifold, k&n 4 inch filter, dynomax ceramic coated headers, and straight 2.5 inch duals out the back. It fries the tires with little effort. You'll like your new mill.
Old May 18, 2008 | 04:57 AM
den(thevetteman)78
I will have the exact setup as you have.
Mine is the long block version as well(less manifold,carb,filter and exhaust).
I just put my new intake,600 carb, and air cleaner from edelbrock and my headers just to see what it would look like. And i'm running 2.5" true dual strait to the back.
Old May 18, 2008 | 12:07 PM
Kellys~hotrods
Just so you know, that edelbrock carb doesn't run so good out of the box. Mine has different springs, main jet, and metering rods. As for the exact ones, a friend of mine tuned it (an old school drag racer and phenomenal car restoration expert) so i'm not sure exactly what is in it. If you like I could try to find out, mine runs sweet now. Smokey burn-outs are the best!
Old May 18, 2008 | 02:57 PM
rudolph schenker's Avatar
rudolph schenker
Looks good! Congrats!
Old May 18, 2008 | 05:43 PM
Kellys~hotrods
This is what mine sounds like with dynomax race bullets:
http://smg.photobucket.com/albums/v2...rent=00010.flv
In my 1978 Chevy Stepside, and be warned the video was taken while I was using the flame throwers. You can still hear it pretty well though.
Old May 18, 2008 | 10:41 PM
CheezMoe's Avatar
CheezMoe
St. Jude Donor '11-'12-'13,'19-'20
Very cool....Take your time! Double and triple check everything! A day or two extra will be well worth it.
To Got my crate engine today
