Need Help 72 LT1 Numbers
Old May 31, 2008 | 12:16 AM
Shark 2's Avatar
Shark 2
Default Need Help 72 LT1 Numbers
Does anyone have a list of part numbers to help me identify my 72 LT1?
I wanted to verify the engine, trans, rearend, starter, carb, manifold, Exhaust manifold, pulleys, half shafts, frame, dist.tach, etc. I would like to know what is authenic and what has been replaced.
Thanks in advance. Terry
Old May 31, 2008 | 03:34 AM
rvazquez's Avatar
rvazquez
St. Jude Donor '24-'25-'26
Default here are some #'s
some #'s that should be on your 72 LT-1;
Carburetor - Holley R6239A Chevrolet no.3999263
Distributor - Delco 1112101 look for small metal band with this part# embossed on it located right above the dist.hold down clamp.
Alternator - 1100950
Engine Block - 3970010 or 3970014(late production) with a engine suffix code of CKY (if you are lucky enough to be one of the 20 or so ZR1 owners the suffix code would be CKZ)
Exhaust Manifolds - Left and right casting numbers are 386711 (3932461 late production)
Intake Manifold - cast aluminum #3959594
Starter motor - 1108418
Water Pump - 3991399 or 330813 late production
you might want to get a book by Richard Prince titled "Corvette Restoration Guide 1968 - 1982" it proved very helpful to me during the restoration of my car.Also check out the NCRS website for books that will help with all the correct part numbers
How about some pictures of your Car??
here is one of mine
Old May 31, 2008 | 09:15 AM
R1234's Avatar
R1234
Terry,
A useful guide would be a NCRS 70-72 judging manual. It will give you all the correct info needed for you to determine if your cars part numbers and date codes fit your cars build date.
That's how I did it.
Bryan
My 1972 Corvette LT-1 Info
Trim tag;
Build date - I27 - April 27, 1972
Paint code - 946 Elkhart Green
Interior Trim - 421 Saddle - Leather - Deluxe
Vehicle Identification Label - 1Z37L2S519882
Windshield pillar -1Z37L2S519882- April Corvette final monthly serial numbers - 519993
Tach- 5600 redline
Engine casing # - 3970010 - Date B112 - February 11, 1972
Engine pad stamp # - 12S519882 V0422 - April 22, CKY -LT-1 1972
Driver’s side head - 39733487 X 02 2 guide plates visible.
Carburetor - 3999263 Primary - 7102 Secondary - 7101 Source - 6239-1 Date= 1B2 - 1971 Dec. 2nd week
Distributor Tag - 1112101 Date = 2D5 - April 5, 1972
Coil - 202
Exhaust Manifolds - Driver= 3932461, Passenger= 3932461
Alternator - 61A 1100544 , Date= 2C7 - March 7, 1972
Starter -1108418
Fuel Pump - ????
Fuel line = 1, no return.
Master Cylinder - 5480346
Smog Pump - 7801149 Date= 04221S - Feb 11, 1972, shift=1, model= S
Diverter Valve - 29199, code -GL
Check Valves - left, right -5361992
Air Hoses - Left= 3932476 GM RC KV, right= 3947740 GM JA
Fan - Date= D72 - April 1972
Transmission - P2D20 A = M-20, vin #- 12S519882
Differential Code - AA W 103 E 1 = 3.55 ratio, Warren, April 12, Eaton, Shift-1 HD caps.
Old May 31, 2008 | 09:16 AM
Alan 71's Avatar
Alan 71
Hi Terry,
As rvazquez has suggested you should think about getting the '70-72 Corvette Technical Information & Judging Guide' from the NCRS. It will give you lots of good information about your car. You can order it from the NCRS site.
Regards,
Alan
R1234's Avatar
R1234
rvazquez,
Beautiful car! I love the color.
Bryan
Old May 31, 2008 | 10:15 AM
Shark 2's Avatar
Shark 2
Thanks Guys,
There's a wealth of information that you supplied me and I'll order the book. Great looking LT1's. Terry
To Need Help 72 LT1 Numbers
