Should you remove battery?
Old Sep 19, 2008 | 07:07 PM
nutsy's Avatar
nutsy
Default Should you remove battery?
i now have a battery kill switch on terminal. so is it neccesary to remove battery for winter storage? the car is in a heated garage. or can i just cut power with switch? thanks, nutsy.
Old Sep 19, 2008 | 08:11 PM
7T1vette's Avatar
7T1vette
No, you don't have to remove it. If it is going to be extremely cold where you are storing it, you might want to attach a trickle charger to keep it charged and warmed up a bit.
Old Sep 20, 2008 | 02:40 PM
Lon Wayne's Avatar
Lon Wayne
Did you say heated garage ? I leave mine out in the yard in a shed i built just for the car.I just fill it with gas change the 710 and forget about it till spring, my Die Hard Has Started that car for 3 yrs in a row in the spring . Cut the power to the switch if your worried but it should not be a problem.
Old Sep 20, 2008 | 03:04 PM
nutsy's Avatar
nutsy
yah, its heated but not hot. maybe around 50 degrees in winter. i put the kill swich in because i have a draw and never bothered to track it down. kill switch made it not a priority. i also change the 710 although i never saw it worded that way.
Old Sep 22, 2008 | 12:40 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
What is the "710"?
Old Sep 22, 2008 | 12:48 PM
Rickster - C3 69's Avatar
Rickster - C3 69
Change the oil I would guess? Never heard it worded that way either.
Old Sep 22, 2008 | 12:59 PM
rcread's Avatar
rcread
If you turn the "OIL" cap on the valve cover upside down, it reads "710". It's an old joke. Funny, but old.
Old Sep 22, 2008 | 01:22 PM
Derrick Reynolds
Not too old IMO, I fell for it hook, line and sinker!
PK
Old Sep 22, 2008 | 05:19 PM
Alan 71's Avatar
Alan 71
GOT ME, TOO!!!
Regards,
Alan
Old Sep 23, 2008 | 12:38 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
A lady wrote in one day what goes in that 710 cap in the engine I am surly not that old that I thought of it.
But i wondered how many WTF I would get.
To Should you remove battery?
