question on heat riser valve
Old Sep 26, 2008 | 07:42 PM
Georgia1974's Avatar
Georgia1974
Default question on heat riser valve
I want to wire up the heat riser valve to check. Does the small lever go up or down to open it up. I think down but want to make sure.
Old Sep 27, 2008 | 09:45 AM
Alan 71's Avatar
Alan 71
Hi G74,
The arm and weight are up when the engine is cold. The coil spring pulls the arm down and opens the heat riser valve as the engine heats up.
Regards,
Alan
Old Sep 27, 2008 | 02:51 PM
Georgia1974
Thanks Alan
Just what I needed
To question on heat riser valve
