Windshield frame measurements needed
I am looking for as many measurements as possible..
These measurements would be simple if someone has no carpet or windshield trim installed yet. If not, just give me whatever you can.
1) Floor pan to upper edge of post - (straight down)(both sides) using high point of floor pan (not sump)
2) right upper edge of post to outer front top of left quarter
3) left upper edge of post to outer front top of right quarter
4) top of door stricker to upper edge of windshield post (both sides)
5) top of right door striker to left upper post
6) top of left door striker to right upper post
This should help me make sure that all is square and not layed back....
any additional measurements would also be greatly appreciated!
Thanks!
Louisiananiceguy@bellsouth.net
Last edited by louisiananiceguy L88; Oct 19, 2008 at 07:31 PM. Reason: requesting specific measurements
I'm sorry but my car is back together so I can't help.
I think, however, the dimensions you asked for won't help you because you measuring from the birdcage to FIBERGLASS. These dimensions will vary from car to car. The dimensions to the door strikers will vary too, because of how the door is adjusted on each car.
I think you'll need to measure to other points on the birdcage, but I'm not even sure how much they varied. I looked at my AIM and although it shows in detail HOW the birdcage went together there are no dimensions to check.
At least this will get you to the top again.
Good Luck!
Regards,
Alan
I've recorded the measurements below. Let me know is you need any more measurements or pictures taken.
Regards,
Ian
1) Floor pan to upper edge of post - (straight down)(both sides) using high point of floor pan (not sump) 35 1/2"
2) right upper edge of post to outer front top of left quarter 54 3/8"
3) left upper edge of post to outer front top of right quarter 54 5/8"
4) top of door stricker to upper edge of windshield post (both sides) 29 1/4"
5) top of right door striker to left upper post 53"
6) top of left door striker to right upper post 53 1/4"
Thanks!
The measurements will come in handy. It is tough to get any definitive measurements on these cars as the tolerances are blown away by the assembly process and fiberglass body parts. I wouldn't worry much about the slight differences as it is not uncommon to have slight variances from side to side. I am hoping to get a few different measurements from a few different cars. It really doesn't matter if it is a vert or a t top as the birdcage height and rake are the same. Then, I will take the general average.
From what you provided..., I am pretty freaking close. I do appreciate your assistance and offer for future measurements. I may take you up on that, if needed.
It looks like you have a good start on your project car. Let me know if I can return the favor in any way.
Thanks again!
Dale
I did learn something from the presentation, though. I am curious about normal spacer positioning and normal (average) distance between wiper rest plate and top center of windshield frame.... It seems like my windshield is too low, or layed back (slightly) which has caused the angle of the (bottom of) glass to not have enough clearance for the arms. Does that make sense??
Thanks and kudo's!!
Dale
I know what you mean though. A SECOND PERSON is almost a must.
thanks again for the measurements!!
Dale
Long involved process, but one you don't want to get wrong.
Personally, I would leave the windshield unglued, but fitted, even until after the car has been painted and almost done. Doesn't interfere with finishng the car at all.
Thanks much. My car is painted. I don't know what is taking so long with the pictures. I am simply double checking the cage because the glass was broken when the windshield wiper actuator arm hit the bottom of the glass.
Dale
