1970 4speed LS5
Old Nov 25, 2008 | 02:39 PM
Augustus's Avatar
Augustus
Default 1970 4speed LS5
Looking at a 1970 LS5 Corvette, and it's a 4sp
The Numbers match on the Block and the Tranny.
However no Broadcast sheet and no original Bill of sale.
Is that good enough to say it's an original numbers matching car?
What would the value be on a car like this?
Car drives, and looks great.
Interior mint, and had a body off 3yrs ago.
Old Nov 25, 2008 | 02:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What's the seller asking?
Have you checked date codes?
Old Nov 25, 2008 | 03:03 PM
Mike Ward's Avatar
Mike Ward
Depends on your definition of 'numbers matching'. If you mean 'this is the original engine installed in this car by the factory' you've got a long way to go yet.
Old Nov 25, 2008 | 03:05 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Well, assuming that the numbers on the block and tranny match the VIN, then yes, it is numbers matching by some people's definition. Be aware though that that doesn't necessarily mean it is the original engine due to the proliferation of re-stamped blocks.
IMO, it would also have to have a correctly stamped and date coded rear end before I would call it a "numbers matching drivetrain", but not everyone feels this way. Others would not consider the car truly numbers matching unless the part numbers and date codes on dozens of other parts were correct, like distrib, heads, intake, carb, alternator etc.
How much is it worth? Is it coupe or convertible? What are the other options? Paint condition? Rust on frame or birdcage? More information would be required before I would want to put out a number.
Old Nov 25, 2008 | 03:20 PM
Augustus's Avatar
Augustus
He's asking $30000.00 CDN
Paint is excellent
Chassis underneath looks like brand new.
It has the original AM/FM
Power steering
Tilt steering
Power windows
Power Brakes
Power windows
So check the rear end code too..
What and where would I look for it on the car?
Is it like coded with two letters like a PQ or something?
I don't know if this means anything but
**The tach has the orange line start at 5000rpm and the redline start at 5250 or 5300rpm
Old Nov 25, 2008 | 03:25 PM
Derrick Reynolds
Coupe or convertible?
I am not an expert on rear end codes, so I think you would be better served searching here.
Edited to add this from a recent post by 427SIXPACK: Rear End...Date code Cast in drivers side of housing for the case of '63-'79. In straight axle '53 to '62 Corvettes, the identifier is stamped on the front right side. In the IRS, the assembly date is stamped in identifier on the bottom flange. Gear ratio Stamped in bottom flange as part of identifier as a letter code, such as AW.
Old Nov 25, 2008 | 03:27 PM
wfo76's Avatar
wfo76
That's a red flag right there. LS5 redline is 5600 rpm and that car has a base engine tach.
Old Nov 25, 2008 | 03:31 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
IMHO, as long as its VIN matches the engine's and tranny's stamped numbers, then IT IS numbers matching, never mind the build sheet, bill of sale, POP ... etc. And as far as the "re-stamping" job is concerned, it could be done in any case, with documents or not, and the only way to verify that is by using some expert eyes to check it out, not by some old documents.
Old Nov 25, 2008 | 03:34 PM
GD70's Avatar
GD70
Hard to tell without pics, but I'd guess 30K & up with a frame off done to it, if it is in fact numbers matching.
Old Nov 25, 2008 | 03:38 PM
Derrick Reynolds
Page 15 from my owner's manual for 1970 Corvette lists the following for tachometer details:
Engine Yellow Red
Base 5000-5300 5300-7000
L-46 5700-6000 6000-7000
LT-1 6300-6500 6500-7000
LS-5 5300-5600 5600-7000
Old Nov 25, 2008 | 04:14 PM
Augustus's Avatar
Augustus
No Way.. Are you guys serious??
The tach is for a Base car?
Maybe they restamped the Block?
But to be sure.. Check the rear end code.
It's a coupe.
Here is the link from Autotrader here in canada.3
Guys take a look.
Let me knows what you think.
http://www.trader.ca/powerpage/detai...4&adid=7334381
Old Nov 25, 2008 | 04:24 PM
wfo76's Avatar
wfo76
It's also missing the aluminum expansion tank for the radiator.
Also the exhaust manifolds have plugged AIR holes, the original 70 LS5 did not use AIR.
Got the full tranny stamps? Is it an M20 or M21 4-spd?
Old Nov 25, 2008 | 04:31 PM
Alan 71's Avatar
Alan 71
Hi A,
There is quite a long list of things to check ( sway bars, half-shafts, etc.) to see if this may have originally been a big block car.
It would be nice to start with a clear picture of the pad surface and stamped information.
The car LOOKS nice, but you need to know what you're actually spending your money on.
Regards,
Alan
Old Nov 25, 2008 | 04:39 PM
Augustus's Avatar
Augustus
WOW... See how great you guys are.!!!.. The more eyes the better..
See I forgot to look at the exhaust manifolds. Unreal.
More things uncovered.
So how would the sway bars/Half shafts look if it's a Big Block car.. Anything specific to look at?
Old Nov 25, 2008 | 04:45 PM
wfo76's Avatar
wfo76
SB cars have 3/4" front bar and no rear bar
BB have 15/16" front and 9/16" rear bars
Old Nov 25, 2008 | 05:22 PM
GD70's Avatar
GD70
It's also got a Hurst shifter, which is a good thing unless you're looking for a "original" car. I'd be very careful with this one for that kind of money.
Glenn
Old Nov 25, 2008 | 05:47 PM
CCrane65's Avatar
CCrane65
You'll want to know if it has the correct carburetor as it can be extremely expensive to replace. There is one for a 72 LS5 on fleabay listed at $1595 Buy It Now.
cc
To 1970 4speed LS5
Old Nov 25, 2008 | 05:52 PM
vettali's Avatar
vettali
Actually ,was going to pas by that place tomorrow. I notice it's missing it's ignition shield.I did the plumbing and sprinkler work in that place.
Old Nov 25, 2008 | 05:54 PM
wfo76's Avatar
wfo76
If it's a Canadian car, tell the owner to get the documentation from GM Canada proving it's an LS5.
Old Nov 25, 2008 | 07:05 PM
Derrick Reynolds
It is also missing the stickers for the top of the air cleaner. I would like to replace mine, but I can't find anyone making reproductions at this time. Of course, that kind of thing would not raise the paranoid meter nearly as much as the wrong tach....
