71 radio?
Old Dec 1, 2008 | 08:15 PM
wnmech's Avatar
wnmech
Default 71 radio?
A friend of mine is putting back together a 71 and it has an aftermarket radio currently installed. He is wanting to know which year radios will fit into his instrument cluster? It doesnt neccesary have to be a year dated radio just a factory bolt into the car delco.
Old Dec 1, 2008 | 08:18 PM
400hp427vette's Avatar
400hp427vette
St. Jude Donor '09
I think it's 68-79 radios will fit, ***** and some cosmetics changed from year to year and the part# on the sticker on the side of radio aswell
Old Dec 1, 2008 | 10:00 PM
markdtn's Avatar
markdtn
I believe it is '68-76. There are some differences.
Old Dec 2, 2008 | 01:00 AM
vettebuyer6369's Avatar
vettebuyer6369
I'm pretty sure 68-'76 is what you are looking for. '77 is when the gauge cluster bezel changed.
Old Dec 2, 2008 | 08:10 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
68-76 is a direct fit for the 71 bezel without cutting. Your friend will also need the output capacitor. 1 for mono and 2 for stereo.
Stereo
Mono
Old Dec 2, 2008 | 08:22 AM
wnmech's Avatar
wnmech
So the 68-76 all used the output capacitor? Thanks for the info.
Old Dec 2, 2008 | 08:25 AM
Easy Mike's Avatar
Easy Mike
Yes. AIM shows the installation. It's possible the old original is still up under the dash.
Old Dec 2, 2008 | 02:41 PM
7T1vette's Avatar
7T1vette
The finned aluminum unit is called a "convector", rather than a capacitor. I assume that was because the aluminum piece was used to convect heat away from the power transistors. The convectors did change over the years; but if the head unit and convector are properly matched (1 transistor for mono unit; 2 transistors for stereo unit), I believe that they will all function OK. The '68 and '69 radios are the most expensive; the later year radios will be the least expensive...but still pretty high for a low-power, poor quality unit.
Old Dec 2, 2008 | 04:31 PM
Alan 71's Avatar
Alan 71
Hi 7T1,
You said " low power, poor quality".
This is EXACTLY why I love my 71... I'm able to pay MORE for LESS, for almost every part of it.
Regards,
Alan
Old Dec 3, 2008 | 10:46 AM
7T1vette's Avatar
7T1vette
Alan, that wasn't a 'criticism'...it was just statement of fact. I had an aftermarket unit in my car when I bought it. I pulled it out and spent big $$$ replacing it with an 'original' stereo unit (plus added kickpanel speakers) -- without ever turning on the other unit! I wouldn't have it any other way but with an original Delco head. When you've lived through those years, hearing an 'old' FM-stereo head unit takes you back.... The sound quality isn't what the new ones provide, but it's "real".
Old Dec 3, 2008 | 11:51 AM
jaki30's Avatar
jaki30
Default Green face
I seem to remember that the earlier radios were more expensive since they had the green colored numbers and letters in the dial face. I believe in the 72-76 the color was changed to white. The radio face plate matched the guages face plate colors.
Old Dec 3, 2008 | 11:57 AM
7T1vette's Avatar
7T1vette
The value in the early units is mostly due to lack of availability...especially on FM/stereo units. Fewer numbers = more $$$$.
Old Dec 3, 2008 | 06:23 PM
Alan 71's Avatar
Alan 71
Hi 7T1,
I was just making a joke.
So many things on these old cars, we love so much, aren't very good at all compared to what is availible now for less money. That's what I meant.... I pay more for some part and am glad to have it because it's old and hard to find.
How are your engine and compartment projects coming along? Time for an up-date?
Regards,
Alan
To 71 radio?
