Difference between 70 71 72 ?
Old Dec 8, 2008 | 08:26 AM
vette54728702's Avatar
vette54728702
Default Difference between 70 71 72 ?
Can anyone tell me what the differences between a 70, 71, and 72 Corvette are? Mechanical or by appearance....
Old Dec 8, 2008 | 08:55 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The Corvette Black Book lists a few of the differences and you can check other references. The 70-72 models are very, very similar.
The 70 models have the shortest production run. 70 & 71 have fiber optics and removable rear window. 72s do not. The LT-1 was available all three years and available with AC for '72 only.
70s have the last open element air cleaners.
You can get a brief explanation of the differences here:
You can get specific differences here:
Pricey, but a very good photo reference. The 70-72 NCRS judging guide also outlines the similarities and differences between the three model years.
Old Dec 8, 2008 | 08:58 AM
cnyc31976's Avatar
cnyc31976
Pricey, but a very food photo reference.
Hi, just a minor correction about the removable window, the '72's still have that. I just picked mine up on Sat.
Sorry I just had to chime in. (its the excitement )
http://s430.photobucket.com/albums/q.../1972%20Vette/
Old Dec 8, 2008 | 09:04 AM
myk7's Avatar
myk7
The 70s and early 71s LS5s had chrome valve covers.. then they went to painted valve covers.
70 and most of 71 had clear front turn signal lenses. The late 71s and 72s had amber front turn signal lenses.
There are a few other changes like engine compression and side vent paint, but I'm not sure on the details on those changes.
Old Dec 8, 2008 | 09:09 AM
GD70's Avatar
GD70
It's a long list, and I'm sure I'll leave something out.
70-last of the high compression engines.
Base 350 engine 300 hp
L-46-350-350 hp
454-390 hp
Egg crate grills on fenders are 70 specific, horizontal chrome highlight only.
Front Parking lenses white, amber bulbs.
First year for advertised LT-1 engine 370 hp.
71-Base 350 engine 270 hp
Basically the same styling.
Egg crate grills on fender, horizontal & vertical chrome highlighted and the casting is different.
LT-1 engine 330 hp
LS-5 454-365 hp
LS-6 454-425 hp only year available.
Amber parking light lenses later in the production year. (has been debated when)
72-Base 350 200hp ratings changed from SAE Gross to SAE Net ratings.
Amber front parking light lenses.
Fiber optics eliminated
Last year for LT-1
Last year for chrome bumpers front & rear
ZR-1 option -LT-1 engine, electronic ignition, heavy duty brakes, heavy duty 4-speed close ratio tranny, special shocks & springs, over size aluminum radiator. Only 20 built.
Hope this helps a bit.
There's tons of info on the web.
Glenn
Old Dec 8, 2008 | 09:16 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
Also the two front grills were year-specific for the '70 model, and were the same for both '71 and '72.
Old Dec 8, 2008 | 09:55 AM
70Yellowbird's Avatar
70Yellowbird
Even though the front grilles and fender egg crates have subtle differences in the 70 versus the 71 & 72 parts, I believe they all fit interchangeably in all 3 year models.
The 70 front grilles have 1 screw hole and 2 studs for mounting each grill in place, while the 71 & 72 grilles have 3 screw holes.
Old Dec 8, 2008 | 10:59 AM
moosie982's Avatar
moosie982
L-46-350-350 hp
454-390 hp
LT-1 engine 330 hp
LS-5 454-365 hp
Last year for LT-1
Glenn
The '71 that I bought brand spankin new had a vin.# of 194671S101719 would make it an early car I think ( dont have a build date ) had clear parking light lenses with the amber bulbs, other then that , I wish I still had it. Peace,,, Moosie
Old Dec 8, 2008 | 12:14 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by ondagawood
...Hi, just a minor correction about the removable window, the '72's still have that...
Yup. They do. My bad.
Old Dec 8, 2008 | 01:43 PM
BlueSkunk952's Avatar
BlueSkunk952
1972 was also the first year for the factory installed alarm system.
Old Dec 8, 2008 | 02:26 PM
Ed Campbell's Avatar
Ed Campbell
All three years of the LT-1 had open element air cleaners. Also the 1971 LS-6.
Old Dec 8, 2008 | 02:39 PM
MikeMc71's Avatar
MikeMc71
The only '70 cars that had EEC system were the California cars. All 71 & 72 cars have the system.
Shoulder belts in the '70 vert were optional.
The '70 models came with headlight washers.
Old Dec 8, 2008 | 02:48 PM
Ed Campbell
Early 1971 cars had headlight washers and clear front parking light lenses. My #1324 have them. I understand they used whatever was in stock and would fit from the previous year on the current production as long is it did not effect emissions etc.
Old Dec 8, 2008 | 05:21 PM
wfo76's Avatar
wfo76
1972
ZR1 available all 3 years, 70-72. Also Transistor Ignition dropped after 71, all 72-74 cars had points.
No, that would be 68. The first year the Alarm was standard equipment was 72 though.
Old Dec 8, 2008 | 05:27 PM
Alan 71's Avatar
Alan 71
If you look at the 'engine data plate' on the shifter console you can tell what year it is. Horsepower #s changed each year. Some people change the plates so it only works some times, but it's the first place I look, if I'm not sure from the exterior clues. (my eyes are getting too bad to always be able to see the year in the VIN).
Regards,
Alan
Old Dec 8, 2008 | 05:33 PM
wfo76's Avatar
wfo76
Well, on the console HP plate, in 72, the horsepower rating did not appear at all, only the displacement, torque and compression.
Guess the numbers were getting so low they didn't want to constantly remind you.
Old Dec 8, 2008 | 05:55 PM
early shark's Avatar
early shark
Several posters have hit on some of the differences between these years. There are a lot more subtle changes.
For interiors, '70 & '71 use the same radio, green dial letters, same plastic chromed *****, and lighted STEREO in bluish green letters. '72 has white letters, rubberized musical note symbols and a red dot light in stereo mode.
'70, '71's use stainless pedal trim, '72 has none. '70, '71's has chrome plated plastic astro vent *****, '72's are black plastic. '70, '71 early use a fiberboard window storage tray and spring steel latching assembly. '71 late & '72 use a fiberglass rear window tray and pushbuttion lock assembly (like storage doors). '70, '71 have console plate provison for rear fiberoptic lenses, '72 does not. Forward console has provisions for fiberoptics on '70, '71, '72 does not. Seat belt mechanisms in '72 way different, '70, '71 the same. Seat upholstery on custom interior option is different for '72 from '70, '71.
There are a lot more differences, but this gives you an idea in the interior changes.
To Difference between 70 71 72 ?
Old Dec 8, 2008 | 08:19 PM
hicswa's Avatar
hicswa
3 years?
Old Dec 8, 2008 | 08:32 PM
lowbuck72's Avatar
lowbuck72
I believe all '72's were design to run on regular gas, even the 454, (main reason they lowered the compression across the board)
Old Dec 8, 2008 | 08:37 PM
Don Rickles's Avatar
Don Rickles
2017 C3 of Year
How about the 70 and 72 had the TCS (transmission controled spark), the 71 had the CEC(combined emission control). In 72 the alarm system became standard equipment.
