Powder coating issue
Old Dec 30, 2008 | 01:48 PM
saudivette's Avatar
saudivette
Originally Posted by 427V8
Nice!
I always preheat my parts before coating. the powder sticks better and more evenly...
I'm not trying to start an argument about it, but saying the powder sticks better and more evenly because a part is hot, is bollocks. That approach is obviously what works for you, and that's completely fine, but for me, I achieve far, far better results spraying the powder "properly". I don't really have any problems with the Faraday Cage effect and I'm only using the Eastwood cheapy.
For someone new to powder coating, I'd say to stick with the "correct" method first. If nothing else, any mistakes are a whole lot harder to clean up if you spray an object hot. If you bugger it up spraying cold, then you only have to blow the powder off with your compressor and start again. Bugger it up hot and you have to actually strip the pc off...
Old Dec 30, 2008 | 06:53 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Wow, have you actually talked to anyone else about powdercoating?
The guys on the coating forums all preheat...(well maybe there are a few who don't)
I started out doing it cold, it's a LOT easier to do it hot, fewer mistakes, a more even coat. If you do bump it or touch it, first you damage it less because the powder is stuck on better, and if you really mess it up you let it cool, sand out the mistake, reheat and recoat.
Old Dec 30, 2008 | 10:24 PM
Skip Burney's Avatar
Skip Burney
I have a good friend who owns a powdercoating business and all of his stuff is slightly preheated, he has this huge machine with several stations the parts move hanging from a chain conveyer first to an alkaline cleaning bath then they move to a wash station that uses heated water to remove the alkaline cleaner, then they move to a hot air dryer and then to the actual coating booth from there they move to a station where the parts are hung on big racks with rollers and they are rolled into a big oven to melt the powder and slow cool to cure them. Hope this helps
Old Dec 31, 2008 | 01:41 AM
saudivette's Avatar
saudivette
What are you talking about? Pre-heating the parts or hot-flocking? I'll agree with you that most people pre-heat parts however, ask those same forum guys and see if they hot-flock everything.
There's a world of difference between pre-heating and hot-flocking, and I disagree completely with your comment "it's a LOT easier to do it hot" - this is obviously what works for you. If you find it hard to do with the parts cold then I think there's a problem with your gun.
