dying interior
Old Apr 5, 2009 | 09:29 PM
sweeet76's Avatar
sweeet76
Default dying interior
Im in the process of dying my interior but going to use the original color ( dark brown). I know the key to this is to get all dirt, armor all, and any other grime which may have accumlitated over the years. I,ll confess upfront, Im nowhere near a painter but I thought I could handle this. After cleaning, I used special plastic prep and then plastic
primer. I actually let everything dry over night, then sprayed with the dye. After the dye dried,it all came out splotchy looking.
Im always amazed at the knowledge on this forum so hopefully I will be able to get some opionins on what went wrong.
Thanks,
Sweeet76
Old Apr 5, 2009 | 09:48 PM
81shark2008's Avatar
81shark2008
your not suppost to let the plastic prep dry to long, it's supposed to flask(semi dry shiny looking) then give another coat and then dye when that coat flasks off, you waited to long and the prep wore off, and use good stuff also i used the s.e.m from a pro paint shop, go to a local auto paint shop and buy a system, i ended up changing the pieces any way becuase in my opinion it will always have a problem. i've done it several timesd and even had a shop do it and it still wasnt right. i just replaced the parts with new so i had the piece of mind and no worries when someone or something toughed it about it rubbing off, jmo good luck
Old Apr 5, 2009 | 10:08 PM
sweeet76's Avatar
sweeet76
Do I need to get everything off and start over?
Old Apr 6, 2009 | 08:16 AM
7T1vette's Avatar
7T1vette
What brand of "dye" did you use? Was it in a spray can or did you buy liquid dye and spray it yourself?
Old Apr 6, 2009 | 10:40 AM
sweeet76's Avatar
sweeet76
I bought a pint of dye from ecklers and used it in a small wagner spray gun
Old Apr 6, 2009 | 10:58 AM
81shark2008
i used spray can, never tried it your way so im not sure but yeah i would try again and if it still doesnt work i would buy new, i found that i spent alot of money and time dying and taping everything off and bought new anyway because it looks better. on alot of the older plastic the texture is alittle different and you can almost tell it is dyed, it kinda looks fake imo and smells like paint in the car for a long time
Old Apr 6, 2009 | 09:30 PM
trw's Avatar
trw
Not to highjack the thread.
What did you use to thin the dye?
Is it water or paint thinner?
I just bought a quart and am about to spray also.
Terry
Old Apr 6, 2009 | 09:42 PM
sweeet76's Avatar
sweeet76
I used paint thinner mixed three parts dye to 1 part thinner
Old Apr 6, 2009 | 10:25 PM
7T1vette's Avatar
7T1vette
I can't imagine needing to "thin" vinyl dye; and I'm surprised that something that thin would spray at all from a Wagner sprayer. Interesting.
Old Apr 6, 2009 | 11:51 PM
TX-Techman's Avatar
TX-Techman
Default Just redyed my 69, looks great!
I used the C.A. rattle cans in bright blue.
Prep Clean - rubbing alcohol this will remove the old dye as well and dries quickly.
Dye Primer from C.A. too, light coat then coated with the color while still tacky. If you need another coat do not prime again just another light coat.
I had all the parts out and dyed the door panels, dash pads, console, brake console, seat backs, kick panels .... and get compliments all the time.
Pictures, still a few things left to finish up but gettting close!
http://s203.photobucket.com/albums/a...69%20Interior/
Old Apr 7, 2009 | 08:55 AM
81shark2008
that does look pretty good
Old Apr 7, 2009 | 07:44 PM
hicswa's Avatar
hicswa
Call Ecklers. I found there techs to be pretty good with product info.
Danny
To dying interior
