some help would be appreciated
Old Aug 30, 2009 | 07:01 PM
panicman's Avatar
panicman
Default some help would be appreciated
My uncle reacently passed away and in his garage is a 1968 corvette. The car is a 427 4 speed 390 hp. coupe he was the oridgnal owner. The car has been sitting since 1984 and has 60,000 mi.. the exterior is covered in bird crap but the interior is pirfect. I do know the car was hit in the left front in the 70's but not how bad. My father is the executor and I would like to buy it at an honest price. Does anybody have an idea as to the value. I will try to take pictures and post them but I want to wash it first. If you have more questions I will try to answer them.
Old Aug 30, 2009 | 07:22 PM
wildman378's Avatar
wildman378
I sent you a Private message
Old Aug 31, 2009 | 05:59 PM
Alan 71's Avatar
Alan 71
Hi PM,
I'd think the value depends on whether the bird crap is original or has been restored.
Not much info on the car to make even a guess.
Regards,
Alan
Old Aug 31, 2009 | 06:14 PM
SEVNT6's Avatar
SEVNT6
Originally Posted by Alan 71
Hi PM,
More info & pics..........
Old Aug 31, 2009 | 08:06 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
Old Aug 31, 2009 | 08:52 PM
Leung's Avatar
Leung
Old Aug 31, 2009 | 10:58 PM
jimo's Avatar
jimo
Old Aug 31, 2009 | 11:07 PM
Goody's Avatar
Goody
No way to give a good anything, without more details and pics. The engine/tranny combo makes it worth investigating for sure but until it is out in the light for a good thorough inspection it is only of value as a parts car for now.
Old Sep 2, 2009 | 10:27 PM
panicman's Avatar
panicman
Ok here are some pics. The antifreeze is good so I don't think the block is cracked. The frame is flaking but solid. The doors open and close smooth. The brake lines and fuel lines need to be replaced. The paint is stained from the bird crap. The wheels do not turn so I can't get the car out of the garage.
Old Sep 2, 2009 | 10:34 PM
72LS1Vette's Avatar
72LS1Vette
The pics don't work. Flaking on the frame may be OK or bad - need closeup pics to tell for sure, especially the trailing arm pivot/differential crossmember. The E-brake shoes are probably rusted to the back of the disks. Spray PB-Blaster through the acess holes and also down though the rotor vent holes until you can turn the rear discs a bit. Work them back and forth and eventually you will be able to roll the car.
Rick B.
Old Sep 2, 2009 | 10:41 PM
panicman's Avatar
panicman
I can't get the pictures to work.
Old Sep 2, 2009 | 10:42 PM
panicman's Avatar
panicman
Old Sep 2, 2009 | 10:48 PM
dbeall1968's Avatar
dbeall1968
Can't get your link to work. I got to the pics by copy/paste the url in the browser bar.
some help. Nice car, the interior looks great- I guess the car was stored well. Engine bat needs a resto, I assume the underneath & brakes, too. Probably needs a total restoration, simply from sitting. A great place to start, however. It looks like a very original car.
Old Sep 2, 2009 | 10:59 PM
DZRick's Avatar
DZRick
http://s644.photobucket.com/albums/uu168/panicman98/
Looks like a decent project.
Old Sep 2, 2009 | 11:13 PM
Frogday's Avatar
Frogday
Old Sep 2, 2009 | 11:14 PM
Frogday's Avatar
Frogday
I don't think the bird crap is original, it looks aftermarket to me.
You might be able to rub out a lot of the stains with a buffer and some medium to heavy cut cleaner.
Old Sep 2, 2009 | 11:16 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Hi PM,
Regards,
Alan
Alan, you are spot (pun intended) on with this one. How do we know that the bird crap has not been imported from China? With little to no information it will be a little difficult to offer a fair market value for the car. Maybe someone in your area that knows Corvettes could step up and offer a helping hand, after the car is washed of course. Good luck.
David
To some help would be appreciated
Old Sep 2, 2009 | 11:24 PM
AllC34Me's Avatar
AllC34Me
Senior Member
St. Jude Donor '10
Actually, that looks like you might have a good car to restore there. Good luck with your decision and the project. Is that a 1968 color on the car? Check the plate on the inside of the drivers side door panel for build date, body and interior codes. Then consider getting yourself a Corvette Black book to help sort out what that data means. If the door code is 986 then the exterior color should be Silverstone Silver. If the interior code is 442 then the interior should be gunmetal; and so on. Looks pretty good for sitting so long. Sorry he didn't cover it from the birds.
David
Old Sep 3, 2009 | 12:03 AM
SEVNT6's Avatar
SEVNT6
Times ten........
A one owner BB with only 60k that's had a roof over it long enough to get that much crap on it? I think you have a real diamond in the rough there....
Now what's a fair price, especially under the circumstances....
Old Sep 3, 2009 | 07:29 AM
panicman's Avatar
panicman
Some people have told my father that the car is worth around $20,000
this seem a little high after checking on the net. Nobody has seen it in person.
