I spent yesterday under the dash of my '72 replacing switches. The first was easy and took minutes: the wiper over-ride. The turn signal switch took longer, especially 'cause the dealer (now out of business) sold me the wrong switch. The plug looked the same, but was about 1/8 longer, so I had to carefully change the prongs into the old one. Then I changed the ignition lockout switch for the clutch. It is held on by one screw, but placed in such a difficult position that it took about three hours on my back on the floor, hand cramping, while I worked with a 1/4 drive socket wrench. Whoever planned it should be forced to drive a Yugo in rush-hour LA traffic for the rest of his life!
The hardest problem was getting my hand up around all the brackets, rods and pedals and getting the wrench on the hex-head screw. Then getting it started back in was just as bad. My hand kept cramping from the weird position.
good for you guys that you CAN do it! Maybe it would help if I removed the drivers seat, but there were a few under-the-dash jobs that I just couldn't do because I get too claustrophobic under there. When I start to feel like I can't breathe and might puke I really can't finish the job.
I've restored a couple C3's and it would a lottery winning if I got a buck for every time I mumbled under my breath "whoever designed this thing should be shot...then hung"
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
My hands are a lot like tennis rackets. So I wait until I have a number of good reasons to get under the dash, then just take it all out (again), fix everthing that has gone bad, and put it all back together again. Still a pain in the backside.
Under dash is a real challenge sometimes for sure but---door glass adjustment is my nightmare! When one side seems to need to go all the way in one direction for fit and the other side needs all the way the other way for fit!! You put all new weatherstrip and the glasses just don't seem to be just where they should be---close but no cigar?!!!
Has anyone changed the hood release bracket? I was going to do it while I was doing all the other stuff, but it looked like a pain and I was out of time. It looks the A/C outlet on the dash blocks the bolts. but I might get at it with an open-end wrench. Before I start I want to know how much grief to expect.
