New Clock
Old Sep 9, 2009 | 07:23 PM
dar322's Avatar
dar322
St. Jude Donor '12-'13
Default New Clock
Well, bought a new quartz clock to replace the non working one. Problem will be asthetics. All the other gauges look old. Will NCRS deduct points for this?
Old Sep 9, 2009 | 07:38 PM
C3 Stroker's Avatar
C3 Stroker
If asthetics is the only issue, why not buy the other new gauges to match?....then the NCRS will see them as "perfectly restored".
Old Sep 9, 2009 | 07:41 PM
dar322's Avatar
dar322
yeah maybe down the road when I got less to do and more money in my pocket.
Old Sep 9, 2009 | 10:31 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Dar:
NCRS will doc you on the quartz clock. I'm not sure what the deduction is, you might try to contact a judge in your year or maybe post a question on their board and ask.
They will listen for the ticking noise the quartz will not have.
Willcox
Old Sep 10, 2009 | 07:01 AM
dar322's Avatar
dar322
well there's good news in all this...at least now if anyone hears any ticking, we'll know it ain't the clock.
Old Sep 10, 2009 | 06:04 PM
Alan 71's Avatar
Alan 71
For anyone who cares....
The appearance of the clock is part of the Interior judging; 10 points divided between all five gauges in the cluster. BUT the way the clock works is part of Operations.
A quartz movement is a deduct... 25 points. OUCH!!!!!
Regards,
Alan
Old Sep 10, 2009 | 07:06 PM
gq82's Avatar
gq82
I went the other route...I replaced my quartz movement with a nos movement. When I first had my car judged I might have been given a break....they only deducted 12 pts for the quartz because the clock line item contains "Clock & reset function"....my reset worked.
Old Sep 10, 2009 | 08:49 PM
Douglas Mariani's Avatar
Douglas Mariani
GM Cert Corvette Tech
Pro Mechanic
RUN!!!!!!
Old Sep 10, 2009 | 10:20 PM
0Willcox Corvette
Former Vendor
I've never tried it, but you should be able to swap the face on the new clock to the face from the old one.
This will make them look the same installed.
Keep the old movement, they can be repaired. . . . for how long is another subject. Some will run for years, some will last a few months.
Willcox
Old Sep 12, 2009 | 06:59 PM
dar322's Avatar
dar322
with some help from my forum buddy Dean ('75) the new quartz clock is in, but just like the old one, doesn't work. Actually it'll work for a few minutes and then quit. good news is I shouldn't lose any NCRS points with a non-working quartz that doesn't tick tock.
Old Sep 12, 2009 | 07:16 PM
danthony's Avatar
danthony
2024 C3 of the Year Finalist - Unmodified
You will lose points for the non working part anyway.
Old Sep 12, 2009 | 09:05 PM
'75's Avatar
'75
Dan, I've got good news, I disassembled your old clock and lubed it with a little WD40 and it is working good.
Old Sep 12, 2009 | 09:07 PM
'75's Avatar
'75
How's the new stereo working, hopefully better than the new clock!!!
Old Sep 13, 2009 | 12:55 AM
7T1vette's Avatar
7T1vette
Hey, those "non-working" clocks are exactly right twice a day! Working clocks are never exactly right.
Old Sep 13, 2009 | 08:45 AM
dar322's Avatar
dar322
Hey Dean, the radio is fantastic. Got it set up last night and my neighbor joined for a cruise. Using your Mirror Glaze, he commented all gauges look brand new. As far as the new quartz clock, it works for maybe one minute and stops. So, the old clock...does it tick? You busy next weekend?
Old Sep 13, 2009 | 08:50 AM
'75's Avatar
'75
No plans next weekend. I'm going to hook up your old clock to a battery and let it run all week to make sure it's ok.
Old Sep 13, 2009 | 09:02 AM
dar322's Avatar
dar322
Just a shot of wd40 did the trick, huh?
Old Sep 13, 2009 | 09:17 AM
'75's Avatar
'75
Yea, runs like a clock
Old Sep 13, 2009 | 11:25 AM
0Willcox Corvette
Former Vendor
You might take a jewelers file and dress down the points on the electro magnet. They get burnt and will reduce the throw on the winding arm.
Also, clocks can be adjusted by moving the time back 12 hours to slow and forward 12 hours to speed up.
Inside the clock is an adjustment lever on the spring that you can move if you have the clock apart. This is the fastest way to make a correction.
Be very careful not to knock the main flywheel off too! They are real hard to get back on.
Willcox
To New Clock
