1968 Chevy Orange
Old Sep 18, 2009 | 01:37 PM
Raptor119's Avatar
Raptor119
Default 1968 Chevy Orange
I want to repaint the heads, intake and valve covers on my 68 327. The color orange for that year appears darker and more red than later versions of the orange that I've seen. I'm not sure how the engine orange color changed over the years or when. Am I imagining it or are there different shades of Chevy orange engine paint?
Does anyone have recommendations on the color and the type of paint to use? Would prefer spray bomb cans as opposed to something I'll have to spray thru a gun.
Thanks!
Old Sep 18, 2009 | 02:05 PM
fdunford's Avatar
fdunford
I'm not sure about color variations over the years, but I can comment on paint bands. Over the last year and a half I painted my valve covers twice - both times using Chevy Orange out of a spray can. Each time the covers were sand-blasted and cleaned prior to painting. The first time I used Seymore paint and primer which peeled off after about a 1/2 year. I then redid the job using Duplicolor ceramic and it is holding nicely and I suggest their paint over the former.
Old Sep 18, 2009 | 03:58 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
"Chevy Orange" is generic and probably changed a bit over the years. As long as you stayed away from either end of the spectrum (flaming red on one end and Orange Crush orange on the other), you'd probably be okay.
Old Sep 18, 2009 | 04:07 PM
Alan 71's Avatar
Alan 71
Hi R119
I agree that the color varies from manufacturer to manufacturer.
I'd chose a high-temperature paint which decreases the amount of 'darkening' on the manifold's heat crossover. You really can't go wrong if you follow Mike's point.
Regards.
Alan
Old Sep 18, 2009 | 05:06 PM
JIM's Avatar
JIM
Use VHT brand Chevy Orange. You can get it from Summit.
Old Sep 18, 2009 | 05:23 PM
Raptor119's Avatar
Raptor119
Thanks for the feedback guys!
Old Sep 18, 2009 | 06:06 PM
7T1vette's Avatar
7T1vette
The key to engine paint staying on the metal surface is in the prep work and primer you choose.
Old Sep 18, 2009 | 07:26 PM
AWilson's Avatar
AWilson
I was advised to use Hirsch paints. So far it seems pretty good. Covers great.
http://www.hirschauto.com/
To 1968 Chevy Orange
