Battery Location
You can't move the battery to the other side because that would throw the critical balance of the car off. AND, as soon as you started to go around a right hand turn the car would flip on to it's side.
That's the best I can do.
Regards,
Alan
Stay in tune....
All I can come up with to reply to the OP is
WHY??
David
God forbid), that's a lot of "G's" on a fairly large mass and it has to be restrained.
However, I've learned there are lots of reasons why it isn't an easy/smooth change so I'll leave it as is.....my plan was to cut the bottom 3" off both boxes, switch them & refiberglass....but, as I said, because the corners aren't all square, the passenger box wouldn't work in the driver hole.
I nominate Alan 71 for the CF Hall of Fame!
The engine (550#) and manual trans (80#) weigh about 630 pounds. The pair are off set 1 inch (IIRC) to the right. This is a weight transfer/torque of 630# x (1/12)' = 52.5 foot pounds to the right.
(If I'm wrong, and the powertrain is shifted over two inches, then the numbers come out to 105 foot pounds.)
Now, the driver (180#) and the battery (30#) at 210 pounds total. I'm guessing the driver and battery are about 10 inches to the left of the vehicle centerline. Let's do the math: 210# x (10/12)' = 175 foot pounds to the left. 175 >> 52.5!
Now, most road courses (the Corvette is a sports car, after all) are run in a clockwise direction. This means that the majority of corners are right hand turns. A left side weight bias is not the best way to build a car that is turning right most of the time. Moving the battery to the right side is a wise engineering move. I applaud the OP.
And let's face it, how often do you get a flat tire? I've had one blowout in the 35 years I've owned my '69. I haven't exactly worn out the door hinges on the jack storage compartment at this rate.
