AC212 CW Repro?
Old Jan 28, 2010 | 09:37 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
Veteran: Marine Corps
St. Jude Donor '25
Default AC212 CW Repro?
Guys, a friend called and wants to know if there is any way, specifically to tell the difference betwen a repro AC 212 CW open element filter and an original? I know the repros have the square mesh now and are ususally yellow over time.....any other way? Thanks for any help, take care, john
Old Jan 28, 2010 | 10:14 AM
SBR's Avatar
SBR
John, there are several versions of original 212 filters depending on when the car was made. Check the NCRS forum archieves as there have been disussions on this subject.
Old Jan 28, 2010 | 11:02 AM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Thanks, guess this is for the 68? square mesh?
Old Jan 28, 2010 | 11:09 AM
SBR's Avatar
SBR
I believe that it should be a cross mesh rotated 45 degrees.
Old Jan 28, 2010 | 12:40 PM
gbvette62's Avatar
gbvette62
The 65-69 element had the mesh installed on a bias, at a 45 degree angle. The 70-72 elements have the mesh installed horizontally.
The elements made by Paragon ($60.00ea) are pretty good. They are available in either mesh and have the correct, silk screen instructions. Still, like any repro part, it's tough to say if it's perfect and then when you throw in the opinion of an NCRS judge, who knows!
If he's worrying about NCRS judging with it, a post on the NCRS forum, or a call or e-mail to the national team captain, for the year in question, might yield a more difinitive answer.
Old Jan 28, 2010 | 12:52 PM
Rowdy Rat's Avatar
Rowdy Rat
Chuck Berge is the 1968-1969 Team Leader... His number is listed over on the NCRS website.
The reproduction AC212W air filter from Paragon is passable. It has the general look of the original, but there are quite a few detail items where it falls short. Still, for $60, it isn't a bad deal. From what I have observed from the 1968-1969 and 1970-1972 teams, the Paragon reproduction will cost you a point or two on originality at an NCRS regional or national event... Basically a drop in the bucket on a 4500 point scoring system.
If you have to garner all the points, locate one of the NOS air filter elements that turn up from time to time. Last I heard they were going for $300+.
Regards,
Old Jan 28, 2010 | 01:11 PM
SBR's Avatar
SBR
Stan, I have even seen the first design embossed 212 filter which is correct for 65/7 go for as high as 2500.
Old Jan 28, 2010 | 09:24 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Regards,
do you happen to know what the small differences are between the repro and original?
Old Jan 29, 2010 | 10:14 AM
Rowdy Rat's Avatar
Rowdy Rat
The font of the text used on the rubber casing differs... So does the style/diameter of mesh used... The original was oil wetted, the reproduction does not appear to be.
For $60 and a loss of maybe one point, the repro isn't a bad choice. If your friend is considering pursuing a Duntov award, then you might want to consider one of the expensive originals still out there.
Regards,
Stan Falenski
Old Mar 1, 2010 | 07:24 PM
BoeingDriver's Avatar
BoeingDriver
Here are a few PICS to illustrate what Stan is describing.
This filter was purchased by me NOS and the box date is shown below.
The font differences between the reproduction and original are easily discernable and there is a groove around the entire circumference (front and back) that, I believe, the repro doesn't have.
On the back, there is embossing.
The element is heavily oil wetted on the original and the wire screen, for 1969, is a very heavy gauge biased design. The reproduction is much thinner and a different configuration. Again, this example is from 1969. Other years as well as within model years can be very different.
There are other differences but these are obvious to an experienced judge.
Regards,
Mark
Old Mar 1, 2010 | 07:43 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
fantastic!!! thanks Mark!!!
Old Mar 2, 2010 | 06:14 AM
GREGG-73's Avatar
GREGG-73
Talk about ask and you shall receive......my hat is off to BoeingDriver!
Great photo's....and info!
Stay in tune....
Old Mar 2, 2010 | 04:24 PM
Alan 71's Avatar
Alan 71
Hi Mark,
NICE pictures of a part that's talked about but not seen too often. Thanks for taking the time to post them.
Regards,
Alan
Old Mar 2, 2010 | 05:59 PM
avalonjohn's Avatar
avalonjohn
CF Community Team
St. Jude Donor '25
Stay in tune....
you're not kidding.....that was above above and beyond!! thanks again!
Old Mar 4, 2010 | 09:21 AM
Robertp535's Avatar
Robertp535
St. Jude Donor '12
Default AC212W Repo
I bought a paragon repo for $60 and I bought one from ebay for $24. Couldn't find any difference. The ebay no. is 230443733579 That's for a AC212W Square mesh. Bob
To AC212 CW Repro?
