Stock alarm: what does it do?
Old Feb 19, 2010 | 04:42 PM
Ryan Kitchen's Avatar
Ryan Kitchen
Default Stock alarm: what does it do?
I've been wondering this since I discovered that little keyhole on my front fender. What does the factory alarm do? And how do you trigger it? I'm pretty sure mine doesn't work, other than to run down my battery, but I'm still interested in what it was originally for.
Old Feb 19, 2010 | 05:09 PM
Alan 71's Avatar
Alan 71
Hi RK,
You don't say what year your car is.
In 68-72 the alarm had 3 switches, each door and the hood. If the alarm was set and they were opened the alarm horn sounded. It was an option through 71 and became standard in 72.
Not quite as sophisticated as todays alarm systems.
Regards,
Alan
Old Feb 19, 2010 | 05:15 PM
nutsy's Avatar
nutsy
HI ALAN, behind my drivers side quarter panel i saw a horn. i figured it was the alarm but it does not work.
Old Feb 19, 2010 | 05:58 PM
oldsarge's Avatar
oldsarge
No, beep ,beep, beep, beep. You will have to check your AIM, it will show you all your contacts, relays, flashers and horn, etc. From there, you will find your problem. Good luck.
Old Feb 19, 2010 | 06:19 PM
nutsy's Avatar
nutsy
thanks OLDSARGE. WILL DO.
Alan 71's Avatar
Alan 71
Hi Nutsy,
I believe the alarm relay and flasher were/are located in the passenger's side rear storage compartment below the lift out fiberboard liner.
Regards,
Alan
Old Feb 19, 2010 | 06:28 PM
Ryan Kitchen
that would explain the clicking sound I get if I turn it on.
Maybe I can fix this!
Thanks all
Old Feb 22, 2010 | 09:51 AM
Stoge's Avatar
Stoge
Goes off in the middle of the night 2 or 3 times a year for no apparent reason.
Old Feb 22, 2010 | 05:35 PM
68/70Vette's Avatar
68/70Vette
My 1970 factory alarm had been buggerized. Cut wires to disconnect it. I bougth an all new repro factory alarm harness. The harness exxtends from the rear of the car (the on/off switch) to the front (the hood close/open sensing switch). It has wires running off the the door open/shut switches in the door jamb, and also wire running to the jack storage compartment where there are some relays, etc. The alarm horn is located between the front top of the drivers side rear well and the bulkhead behind the seats.
Old Feb 23, 2010 | 08:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Ryan -- Do yourself a favor and purchase a reproduction owner's manual for your car. Lots of valuable information in the owner's manual.
Old Feb 23, 2010 | 10:25 AM
gbvette62's Avatar
gbvette62
81-82 have a starter interrupt, so when you trip the alarm, the car won't start. To reset the starter interrupt, you unlock either door with the key. Prior to that, all they did was make noise, for 3 to 7 minutes.
Old Feb 23, 2010 | 10:36 AM
7T1vette's Avatar
7T1vette
For the money you will spend on repairing that "horn beeps, lights flash" stuff, you can purchase a modern unit that relays real-time GPS location and notification to security service and/or police. Do you just want to make it "original"...or do you want to be able to find your stolen car?
Old Feb 23, 2010 | 02:33 PM
Ryan Kitchen
Not really worried bout either. Just curious. Will probably install somethin new eventually, not sure yet though.
Old Feb 23, 2010 | 04:17 PM
lock-n-load's Avatar
lock-n-load
When I turn my alarm key on, all it will do is beep,beep,beep ,,, and wont stop...
checked the contacts at door and hood, still same problem .....
Never easy ..is it ..
Like someone said ...might as well invest in a new alarm system...
To Stock alarm: what does it do?
