1972 engine question
Glenn
Edit; Here's a restored 72 LT-1. Shielding would be the same for yours.
Added thought: Do you have the two upright mounting brackets (on either side of the distributor) that the chrome cover bolted to? If you do, then the hardware was origininally there but the PO dumped it sometime in the past.
Big Block cars only had a chromed box over the distributor, and utilized braided stainless armoured covering on each plug wire.
Small blocks cars used many more pieces of shielding, than a big block. Prior to 71, shielding on small blocks consided of a cover for the distributor, 2 verticle covers one on the left side and one on the right side set of plug wires, and 4 lower spark plug covers one each covering a pair of spark plugs. At some point, Chevrolet found that they could successfully eliminate radio interference without shielding the front 2 spark plugs, in each head. Starting in 71 (or possibly late in 1970), the front covers were dropped, and only 2 rear lower covers were used.
Over the years, the design and configuration of the shielding changed, as Chevrolet found ways to save money making the shielding. By 78, ignition shielding was nothing more than a black plastic cover with silver foil lining and a single cover on the left rear pair of spark plugs.
I'll just add that there was a change in the 'lower' shields in 1970. In the beginning of the year there were 4 lower shields as usual but ABOUT half way through production the 2 front shields were discontinued. This coincided to some degree with the change in the distributor cover. So you can expect to see the spark plug 'heat shields' but not the radio shields on late 70 to 72 cars.
Just a little tid-bit.
Regards,
Alan
I just realized that gbv was posting this info while I was typing...sorry.
Not to wonder off topic too much but I wonder about the LT1 pictured above. Is the open air cleaner element correct? I know my L48 has a dual snorkel closed air cleaner.
