Winter project Updates??
Old Mar 3, 2010 | 02:41 PM
81pilot's Avatar
81pilot
Default Winter project Updates??
OK lets hear the updates on your winter projects, big or small.....I will start with mine:
New oil pan and gaket, new transmission pan and gasket and filter, New plugs, and wires, new valve covers, removed the rest of the emissions stuff including EGR valve, changed to a chrome water neck, new fuel line to pump, new full length 2.5 inch chambered exhaust. Interior: dyed the black visors cinnabar to match interior, replaced header trim peice and dyed to match,replaced steering wheel back to original type and dyed to cinnabar, touched up all the rest of the interior (looks great) ...still to do: new custom spreader bar, change over to non comp Qjet and Dizzy, add lock up controller, install headers (all of which I already have) Install leather/vinyl cinnabar seat covers(here tomorrow), new t-top weatherstrip (here tomorrow), new floor mats(here today). Going to redye the rear carpet since it is in good shape but color faded, after that, the interior will look new again! I need to do a very few other things like add some caulk by the windshield on one side so it does not rust (no birdcage rust at all now). So lets hear it, and see what everyone has been up to, around here driving weather starts now!!
Old Mar 3, 2010 | 04:57 PM
Fonz69's Avatar
Fonz69
Pulled out the 540 BBC and dropped in a 427 with about 600hp
I used the same top end (Dart Pro1 heads with Victor JR and 850 QF) so that my hood air box still matched up with the motor
Have future plans for the 540 and the car came with a 427 originaly so I figured it was the right thing to do
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Mar 3, 2010 | 05:29 PM
JimT's Avatar
JimT
Repaired the battery and tire jack compartments (fiberglassed and added new battery hold-down brackets), had a four wheel alignment done, had the car buffed and it looks like new, installed new ball joints and tie rod ends, and am waiting on a new HEI distributor. I'm getting ready for the SUMMER!!! First trip is to the Corvette Expo in Sevierville, Tenn in late March, about 200 miles.
Old Mar 3, 2010 | 06:10 PM
Sully1882's Avatar
Sully1882
On the 72 coupe.....lots of cursing and frustration followed by more beer consumption.
install interior, remove interior, strip and sand body in prep for new paint job, electrical work and repair from bubba's damage.... now reverse lights work and all gauges light up. Still fiddling with the vacuum system but have most of it working. flushed brake system and installed new bleeder screws, new negative battery cable, refurbished A/c controls, restoring the interior to black instead of the saddle that it came with when I bought it, hopefully paint soon enough... oh forgot to mention heater core replacement along with heat/ AC duct seals.... yep such a joy. Maybe some day I can drive this thing!!! At least I have the C5 to drive when it's decent weather out.
Sully
Old Mar 3, 2010 | 08:08 PM
Tim81's Avatar
Tim81
Started out replacing the Diff front snubber and that turned into all new u-joints and that turned into new poly bushings for the rear end, still waiting to see what this will turn into. Tim
Old Mar 3, 2010 | 08:39 PM
dmeesq's Avatar
dmeesq
Ok now its time to actually work on perfomance and not just looks, new engine, TKO 500 5 speed trans, and stainless headers and sidepipes...
Bored 30 over, flat top hypereutectic 10:1 pistons, Edelbrock RPM heads, matching cam, scorpion roller rockers, ARP bolts, 7qt. oil pan, Edelbrock 800cfm carb, RPM hi flow fuel pump, Performer EPS intake, upgraded 8" balancer, ect. ect. ect. Hopeing for 410 to 430hp.
Custom air cleaner going back on when engine is in car, engine, trans, and new side pipes should be on by 2nd week of march.
Old Mar 3, 2010 | 09:04 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
My focus the past year has been taking weight out of the car. The latest lighter weight item is a cut and rewelded F-car tubular sway bar. It's four pounds lighter than the solid 1 1/8 bar I had been using.
Got some lighter late C3 seats that are going in the '69 as soon as there's a sale on new foam and covering.
A lighter 427 is currently in progress.
Old Mar 3, 2010 | 09:07 PM
69427's Avatar
69427
Originally Posted by Fonz69
[IMG][/IMG]
Is that an aluminum or stamped timing chain cover?
Old Mar 3, 2010 | 09:19 PM
SHOWME's Avatar
SHOWME
My winter plans turned into spring plans.(!#*"! it was COLD!)
After working outside all day through the winter I just want to come home and get warm.(Guess I'm getting old!)
I like the door open when I'm in the garage working but this year I tire of lookin at snow.We are finally in the 40's but the snow is still here and is in no hurry to melt!
So as usual I will be slow out of the gate again this year.
Old Mar 3, 2010 | 09:38 PM
72LS1Vette's Avatar
72LS1Vette
Rebuilt headlight actuators
Cleaned up headlight housings and put in new halogen bulbs
Worked on T56 shifter hole
Finished offset shifter modification
Rick B.
Old Mar 3, 2010 | 09:47 PM
hammadown's Avatar
hammadown
Sully
Another Steel Cities Gray about to be reborn.........
Hammadown
Spocc's Avatar
Spocc
hey Jeff
i put in a new battery & 2 new low-beem lights
& the Batmobile has been running perfect & driving almost every day
Pete.
Old Mar 3, 2010 | 10:24 PM
81pilot's Avatar
81pilot
Originally Posted by Spocc
hey Jeff
Pete.
Well you know me Pete, I can't leave well enough alone! Just dreamin for next winter. I know some serious HP is in my cars future within the next couple of years, and I love lookin into others peoples mods! And your car still looks sweet....by the way, new rear rubber goin on the bike, the 205/55-16 Cooper is already worn out(15K on it), goin back with a 215/55-16 Cooper A/S Sport. Z rated tire. I love love huge car tires on bikes!! Be good Ride Safe! Oh and Congrats to Canda Hockey, that was one heck of a game!!!
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
Sorry to say, I haven't touched mine since November. I'll get it out as soon as the snow melts that's piled up in front of the garage door.
Old Mar 3, 2010 | 10:42 PM
larryg3's Avatar
larryg3
i had a lot of plans but between the economy and the cold weather..... the winter projects will turn into spring projects. Bring on the warm weather.
Old Mar 3, 2010 | 11:01 PM
Spocc's Avatar
Spocc
hey - if we lived closer i'd have you work yer magic on my motor - just have to leave it stock for now - it does purr at idle & runs perfect.
i did the new rear tire (Metzler 200) last August, but i had to stay stock because of the hitch inside the rear fenderwell
good to see you are enjoying yer Batmobile !!
Pete
Old Mar 3, 2010 | 11:21 PM
Fonz69's Avatar
Fonz69
Thats a aluminum one from competition products
http://www.competitionproducts.com/P...uctinfo/58422/
To Winter project Updates??
Old Mar 3, 2010 | 11:59 PM
682XLR8's Avatar
682XLR8
Working on an LT1 intake manifold conversion. The manifold is almost done, I will start assembling this weekend
Our first big run of the year is in April, I want to have this done and have the bugs worked out before then
Old Mar 4, 2010 | 12:10 AM
hwcoop's Avatar
hwcoop
I'm afraid i've been slacking off this winter
I was fixing our driver vehicles, doing house repairs etc
Just about ready to start on the Vette and do a blitz..redo steering box, change trans tailshaft bushing, swap rear end and maybe throw a set of heads on....Dang need a money tree around here
Old Mar 4, 2010 | 01:12 AM
Frogday's Avatar
Frogday
I can't think of a single winter project that I started or completed. Spent months doing an addition to house and garage so I could hold 6 inside. Just finished the epoxy on the floors a few weeks ago and tomorrow I'll be assembling a couple of lifts that will be arriving at 9am.
