Chassis paint for 1970
Old Mar 5, 2010 | 06:39 AM
70 C3's Avatar
70 C3
Default Chassis paint for 1970
Looking for correct black colour and sheen in an aerosal can for general touch up on chassis and undercarriage
Old Mar 5, 2010 | 06:58 AM
CTVETTE78's Avatar
CTVETTE78
Take a look at Eastwood's Extreme Chassis Black. Pretty durable stuff and available in a rattle can.
Old Mar 5, 2010 | 08:07 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Krylon 5 ball semi flat black.
Old Mar 5, 2010 | 09:34 AM
7T1vette's Avatar
7T1vette
Unless using your own spray equipment with a good quality chassis paint, I would recommend a brush-on paint. It will take a bunch of spray cans, and there isn't much paint in one.
Buy a quart of Eastwood chassis black (satin or semi-gloss) or even some Rustoleum semi-gloss black. Be sure to use a rust converter on surface rust before you start painting.
Old Mar 5, 2010 | 12:21 PM
TWINRAY's Avatar
TWINRAY
I used the Eastwood Satin. It covers really well. I used it on my frame on and I think I used 4 spray cans. I also bought a qt. can for some stuff but it leaves brush lines so I tried to use the spray on most stuff.
Old Mar 5, 2010 | 05:04 PM
Alan 71's Avatar
Alan 71
Hi 70c,
I'll agree with the suggestions so far and add 3 more...John Deere Blitz- Black, a semi-flat black from the SEM family of paints, and the semi-flat black from Quanta Products. They're all available in spray cans.
I like the Krylon #1613 the best because of it's sheen and the ease with which it can be successfully touched up. It's not as easy to find anymore.
Regards,
Alan
PS: This picture of my 71 shows #1613 over powder coating which I realize you're not doing. But the look will be very similar.
Old Mar 5, 2010 | 05:43 PM
whitehause's Avatar
whitehause
The Eastwood Chassis black is pretty good stuff. I was just at their show room in Pottstown PA this week and they have an entirely completed chassis with the whole drive train in the middle of the show room to show what all their products look like.....it's a 68 Vette chassis!
Old Mar 9, 2010 | 04:26 AM
hunt4cleanair's Avatar
hunt4cleanair
Alan...looks great! What did you do to the driveshaft? I've got a Pace Car I'm restoring and have looked at a lot of different products in an attempt to get the sheen correct. In fact, I believe I've tried every product mentioned above. Thx for sharing
Old Mar 9, 2010 | 09:28 AM
Mad Vette's Avatar
Mad Vette
I vote for the Eastwood classic black I used about 2 quarts and was able to do my frame and all of my suspension parts.
Old Mar 9, 2010 | 10:53 AM
Easy Mike's Avatar
Easy Mike
...I like the Krylon #1613 the best because of it's sheen and the ease with which it can be successfully touched up. It's not as easy to find anymore...
The 5 ball is supposed to be available from industrial paint suppliers.
http://www.kpg-industrial.com/wheretobuy/nj/
Old Mar 9, 2010 | 04:31 PM
Alan 71's Avatar
Alan 71
Hi h4ca,
The drive-shaft and half-shafts were stripped of rust, and the tubes were given some 'texture' in the 'long' direction with some emery cloth; they should be quite shiny and show longitudinal marks from being 'extruded'. Then the castings were given a 'tiny' bit of cast-blast, a bit of very dark gray was sprayed in a band at the joint between the tube and casting to duplicate the 'heat area' discoloration of the original weld, and then a bit of semi-gloss clear was sprayed on the whole thing.
Remember we do this for fun!
Regards,
Alan
Old Mar 10, 2010 | 05:30 AM
hunt4cleanair
Hi h4ca,
Rust removal...bead blast or some other method?
Old Mar 10, 2010 | 04:21 PM
Alan 71's Avatar
Alan 71
Hi h4ca,
I used a gel rust stripper because blasting the 'extruded' tubes changes their surface 'texture'.
Regards,
Alan
To Chassis paint for 1970
