Cleaning the engine
Old Jun 10, 2010 | 09:30 AM
taylorbg's Avatar
taylorbg
Default Cleaning the engine
When you cleaned your engine, what did you use to get any grease and dirt off before painting?
When you painted, did you use flat or glossy black?
Old Jun 11, 2010 | 08:30 AM
GD70's Avatar
GD70
I use simple green. You may need to use a small scrubbing brush to loosen caked on dirt & grease. Then I use Acetone.
Glenn
Old Jun 11, 2010 | 12:00 PM
builder's Avatar
builder
After a pressure wash, I use hot water and Dawn dish washing liquid with a scrub brush. Then hot water, then some metal etch, then hot water again. Blow it dry with compressed air. Make sure it is dry and then wipe on and wipe off with some PPG or Ditzler wax and grease remover. Then paint.
Old Jun 12, 2010 | 01:16 AM
GPGG70's Avatar
GPGG70
Pertty much what builder said. I would spray the heavy oiled areas with either 409 or purple power then the dawn. Heavy on the dawn to cut the grease/oil. My old tooth brushes where my tools for cleaning and a one inch paint brush.
I bought a couple of 1 quart spray bottles to spray and rinse off the area I cleaned then the grease & wax remover then hi temp paint if the paint was or will be close to high heat. Not all the paint I used was a high temp paint in the engine bay.
Hope this helps.
Old Jun 12, 2010 | 03:42 AM
jimo's Avatar
jimo
im doing the same at the moment, have spent the last few weekends with a tooth brush, wire brush and sandpaper to give it a real good clean before i paint her. lots of fun!!!
Old Jun 12, 2010 | 10:45 AM
7T1vette's Avatar
7T1vette
If you eventually want to clean up the entire vehicle (frame, engine, etc.), you will be time and money ahead to just take it to a place that can steam-clean it all. Believe me, if you have anything like the years of thick grease, dirt, crud on yours that I had on mine, steam-cleaning as a starting point is the way to go.
Old Jun 12, 2010 | 11:28 AM
Jeff_Keryk's Avatar
Jeff_Keryk
I had my 65 442 steam cleaned. Wow, some of the best money I ever spent. The only problem was some valuable air cleaner decals, etc. were removed. I WISH I had done the Vette...
Old Jun 12, 2010 | 03:24 PM
taylorbg's Avatar
taylorbg
Steam cleaning huh? Never heard of that. How do you go about finding a place to do that? Once it has been steamed, is it ready to paint or do you have to some more prep work? Does it take care of any minor surface rust? Whats an approximate cost on that?
Old Jun 12, 2010 | 06:37 PM
72LS1Vette's Avatar
72LS1Vette
Maybe an auto detailer or a car dealer could do the steam cleaning or recommend someone. Most late model used cars get the engine cleaned before they are put on the lot. I would wipe the engine down with laquer thinner after the steam cleaning to make sure you get all traces of oil off. The cleaner the surface the better the paint will adhere. I don't think steam cleaning will do anything to rust. You will have to sand or steel wool the rust before priming.
Rick B.
Old Jun 12, 2010 | 09:15 PM
taylorbg's Avatar
taylorbg
I wonder if this is worth getting.
http://www.harborfreight.com/steam-c...-kit-8823.html
I guess it just depends at what pressure the steam needs to be to do a good job and if this one can get to that pressure.
Old Jun 13, 2010 | 03:56 PM
builder's Avatar
builder
Steam cleaning combines a pressure washer and it also has a boiler on it to super heat the water. They work great, but are much more expensive to rent or pay for their services. I use a small pressure washer with 2750 psi. They cost between $300-500. What you need to do is peel the layers of grease off so you can do some final cleaning by hand with a brush.
Taylorbg - I don't think that steam cleaner is going to come close to doing what we are talking here.
Old Jun 13, 2010 | 05:48 PM
noonie's Avatar
noonie
A steam cleaner is probably the best item for grease, oil and crud removal. You will still have to use a good degreaser and rinse with water afterward.
Had a "Steam Jenny" brand years ago and used it to clean off construction equipment prior to repair or painting. About the only thing that works well, much better than a pressure washer.
Check out an heavy equipment, forklift, even an farm equipment repair place. maybe they can help you, machines are far too costly to buy.
Old Jun 13, 2010 | 07:34 PM
7T1vette's Avatar
7T1vette
A good steam-job will remove ALL of the oil, grease, crud from the various areas of the car. You need to identify all the areas you want treated carefully for the guy doing the work so sensitive areas don't get damaged (electrical wiring, any markings/decals you want to keep). The guy doing the work can regulate how aggressively he uses the steam jet, so you can minimize any damage by being clear on that.
It won't remove rust...but it might blow holes in rusted through metal components. Hey, that makes them easier to spot! To finish paint, all you need to do is wipe the surface with some lacquer thinner or other solvent, then have at it. Believe me, the grief you will save (and all those brain cells that won't get killed by excessive solvent fumes) will be worth much more than the dollars you spend on a good steam cleaning.
P.S. Just look up "Steam Cleaning" in the Yellow Pages or Google it on the internet.
To Cleaning the engine
