What is the difference between these switches?
Hey guys, I have been messing around with my door jamb switch and courtisy light switches. I would like to replace them, but I am not sure what the differences is between the following items on Wilcox corvette's website.
What are the 6 terminals for 8.27? Part Number: 49806.
Here are the two complete switches for 10.95 each
Courtisey light swithc: EC253-2000
Door jamb switch:E3755-36934
What part of the switch is the terminal? Is that the part where the wire connects? This feels like a dumb question
http://willcoxcorvette.com/advanced_...&keywords=door switch
The differences in those switches is length of apply pin, depth of threaded member, number of contacts, etc. etc. Basically, they are all a little different from each other.
You will not get good results from replacing them with 'generic' local auto parts store items due to improper fit. Buy the parts made for your specific applications at lectriclimited.com. They have them all.
Depending on the application you will need no less than 10 of the contacts. ( I prefer to fill all 3 spots in the switch so I would use 15.)
2 courtesy light switches , 3 of the door ajar switches if your replacing the hood switch.
http://willcoxcorvette.com/product_i...ducts_id=25956
http://willcoxcorvette.com/product_i...oducts_id=1197
http://willcoxcorvette.com/product_i...oducts_id=8802
I understand now, The terminals are the small metal peices that go on the tip of the wire that slide into the switches.
I couldn't tell what the picture was for the pack of 6 terminals.
Thanks guys!
James
Thanks guys!
James
(I didnt used to have this problem with the factory switches I used to buy from Chevy.)
