T Top Triangular post
Old Jul 4, 2010 | 06:35 PM
Skip Burney's Avatar
Skip Burney
Default T Top Triangular post
I want to take the small chrome plate with the 2 screws and triangular post off to polish them but I can`t see how to get to the backside of it. Are the nuts captured on the backside so that they don`t fall when you remove the screws. Thanks Skip
Old Jul 4, 2010 | 07:01 PM
Alan 71's Avatar
Alan 71
Hi Skip,
Unless someone has messed with it, there's a captured plate behind the fiberglass for the two screws and the tri-angle wedge.
Good luck!
Regards,
Alan
Old Jul 4, 2010 | 07:06 PM
'75's Avatar
'75
Originally Posted by Alan 71
Hi Skip,
Good luck!
Regards,
Alan
My 75 has captured plates, but I got a surprise when i pulled the screws out of a 78. It was a kind of sinking feeling to hear the nut plate fall inside.
Old Jul 4, 2010 | 07:17 PM
7T1vette's Avatar
7T1vette
If you want to 'play it safe', loosen both screws but only remove one. Turn the outer plate 90 degrees, then put a screw in the 'open' threaded hole. Now you can remove the outer plate without dropping it into 'Never-Neverland'.
Old Jul 5, 2010 | 12:18 AM
CCrane65's Avatar
CCrane65
Option 2 is to put a really strong magnet up to the fiberglass to keep the nut plate from falling until you get the screws back in.
Personally, I prefer the magnets from a failed disk drive. Those little suckers are powerful.
cc
Old Jul 5, 2010 | 01:16 AM
Skip Burney
Thats what I love about this forum, I think I am gonna leave them alone ahd polish them up in place.
Old Jul 6, 2010 | 11:19 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by '75
...but I got a surprise when i pulled the screws out of a 78. It was a kind of sinking feeling to hear the nut plate fall inside.
Fall....all the way to the bottom...been there, done that.
Old Jul 6, 2010 | 11:37 AM
CCrane65's Avatar
CCrane65
Thank goodness there is an access panel in the wheel well.
cc
Old Jul 6, 2010 | 11:57 AM
7T1vette's Avatar
7T1vette
Yes, but don't you have to turn the car upside-down to get that plate back in place?
Old Jul 6, 2010 | 02:24 PM
CCrane65's Avatar
CCrane65
Isn't that what a rotisserie is for? lol
Actually you could drop a long light switch chain down one of the screw holes and run it through the nut plate and pull it up. Similar to what you do to fish a wire through a wall.
cc
Old Jul 6, 2010 | 02:55 PM
GD70's Avatar
GD70
This is the safest bet.
Old Jul 6, 2010 | 03:22 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Hey skip try a dremmell with very little polish Its waht I use on all small chrome.
They have all sorts of diffrent size polish wheels.Mothers chrome polish of course.
Or whats in that reddish tube? motorcycle guys use it flex or Glitz something like that I see it at the car shows.
Old Jul 6, 2010 | 04:14 PM
Skip Burney
I used a wooden pencil in a small pneumatic drill and used the eraser end to polish them with a little red polishiing rouge, they came out really good but I don`t think I will ever remove the screws to much chance for an OH SH-T moment
To T Top Triangular post
