Devaluation effect
Old Aug 24, 2010 | 02:41 PM
Red68Tri's Avatar
Red68Tri
Default Devaluation effect
Question, what devaluation effect, if any, would apply to a #s matching engine that has one cylinder sleeved? I guess also it would be interesting to understand the impact on the value of #s matching car in which engine has been rebuilt w/ non-factory original internal components (pistons, valves, cam, etc.). One of my tri-power carbs misbehaved and spewed too much fuel into the #4 cylinder causing it to crack.
Thanks!
Old Aug 24, 2010 | 05:37 PM
Alan 71's Avatar
Alan 71
Hi R68,
Isn't it pretty diifficult to determine what's been done to an engine internally. The cylinder case casting number, casting date, and stamped information are what determine the engines originality to a specific car.
I'd think you might want to tell a prospective buyer about the sleeve, but I don't think it affects the engine's originality to the car.
Regards,
Alan
Old Aug 24, 2010 | 05:48 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
I have been reading up on the C-3's. I read that numbers matching isn't so popular with the NCHS=is that correct? NCHS. I have read that it is feasable to stamp a casting number on any block to make one think that it is original. And that it's been done in the past. Which then would make two engines with the same number. As for value. I am a firm believer somthing is only worth what someone is willing to pay. Just because a certain car sold at an auction for a certain price, dosn't mean a similar car is worth that. It all comes down to what the economics are for that time, and the demand for a certain object. Thats just my opinion, you know what they say about opinions right? LOL.
Old Aug 24, 2010 | 05:59 PM
vettebuyer6369's Avatar
vettebuyer6369
You have quite a bit more "reading up" to do.
Old Aug 24, 2010 | 06:20 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
You are correct. I am learning somthing new everyday. I just recieved the two books I ordered last week. That is where i found out about stamping blocks.
Old Aug 24, 2010 | 07:00 PM
Alan 71's Avatar
Alan 71
Hi d,
I think what VB was referring to was your point about the casting number.
There are really four pieces of information that are looked at on the cylinder case. (Yes, that's actually what GM called it).
The casting number and casting date (with shift) was CAST into the iron when the case was cast. They're on the rear flange of the engine, behind and below the heads.
The stamp pad is on the cylinder case in front of the right hand valve cover and is a smooth 'broach' surfaced pad. 2 series of letters and numbers were STAMPED there with stamps held in gang holders. The first number is a date for when the engine was actually built and to what specifications. The specifications were determined by a 2 or 3 letter 'broadcast' code. The second string of letters and numbers were the VIN derivative, they tell the serial number of the car the engine was going to be installed in.
I hope this helps your understanding!
Regards,
Alan
Old Aug 24, 2010 | 07:56 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Originally Posted by Alan 71
Hi d,
Regards,
Alan
Thanks, Did they also put #'s on the alt, and water-pump?
Old Aug 24, 2010 | 08:22 PM
Mike Ward's Avatar
Mike Ward
No serious judging organization uses terminology like 'numbers matching', I bet not even the NCHS.
Old Aug 25, 2010 | 12:00 AM
BBCorv70's Avatar
BBCorv70
I've seen some businesses advertise services where they will find you a block with approriate casting numbers, date codes, and will restamp a serial number to fit. If there's enough incentive, big price difference between numbers matching and not, someone will do it. Ethical? No but I'm certain it has been done many times.
The selling price will ultimately be what someone is willing to pay. A non numbers matching car can't really be compared to numbers matching to get an idea of average sale price. The non numbers matching will not interest collectors, making a smaller market. My 2 cents anyway..
Old Aug 25, 2010 | 01:49 AM
early shark's Avatar
early shark
Red68Tri,
I believe there is a big devaluation when an engine that is supposedly the "original numbers matching" is not configured exactly as GM built it. As an example a friend bought a '68 L-68 coupe for 25K. After bringing it home and tearing into it, he discovered that all 8 cylinders had been sleeved back to stock bore having sleeves .70 overbore. A lunati camshaft, aftermarket valvetrain, crankshaft undersize, aftermarket replacement pistons, etc., etc.
The original numbers cylinder case was the only original part of the car, along with a cracked intake manifold under the center service dated carbs. The value of the original numbers matching engine was pretty useless with all the other componentry changed out, it was a far cry from GM originality; and its claim and inference as an original engine because of an original stamping on the front pad was quite askewed as bringing more money because of it.
Old Aug 25, 2010 | 09:01 AM
Mike Ward's Avatar
Mike Ward
Originally Posted by early shark
Red68Tri,
I rest my case regarding the terminology. Perfect example.
Old Aug 25, 2010 | 09:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...I'd think you might want to tell a prospective buyer about the sleeve, but I don't think it affects the engine's originality to the car...
Daanbc: Keep reading. Knowledge is power.
Old Aug 25, 2010 | 09:39 AM
daanbc's Avatar
daanbc
St. Jude Donor '12
Thanks, I am. Just recieved "Corvette C3 1968-1982 Buyer's Guide" and "Collector's Originality Guide Corvette 1968-1982" Hard to retain all the numbers and engine choices for the early years. I guess over time it will become natural, just like when I was learning about camaro's back in the day's..
Old Aug 25, 2010 | 10:24 AM
7T1vette's Avatar
7T1vette
A sleeved cylinder that was done correctly...so the integrity of the original block could be retained...should not devalue the car, except in the most extreme circumstances.
Old Aug 25, 2010 | 11:02 AM
BBCorv70's Avatar
BBCorv70
I don't often hear of blocks being sleeved unless theres something very special about the block, very rare or in this case, has the right serial number. Wondering whether the machinist can make any guarantee as to the success of the repair? Assume the sleeves were necessary because one or more cylinders cracked. If there was a crack, can it be stopped for certain? If the block had been bored to max, sleeves put in to renew the block, is there risk of future problems?
I've rarely heard of sleeving. Wondering how reliable this repair is assuming a competent machinist installed them. I'd feel uneasy with a sleeved block unless I could be reassured the operation has a high success rate. Just asking...
Old Aug 25, 2010 | 11:36 AM
Easy Mike's Avatar
Easy Mike
...Just recieved "Corvette C3 1968-1982 Buyer's Guide" and "Collector's Originality Guide Corvette 1968-1982" ...
I just finished Tom Falconer's C3 book. Not great, but not bad.
Birthplace of Legends Peter LiCastro All about St. Louis.
Rick Bizzoco's 1969 Guidebook http://www.cranescorvette.com/1969_s..._guidebook.htm
Judging guides form the NCRS are also good reading.
Old Aug 25, 2010 | 06:56 PM
Alan 71's Avatar
Alan 71
Hi d,
Yes, there were numbers on the water pump and alternator too.
Actually there were part numbers and dates on many, many parts.
I'll just name a few: (some have one or the other and some have both) some radiators, hoses, fan clutches, intake and exhaust manifolds, carburators, distributors, starters, transmissions, some body panels, windshield and window glass, gauges, seat covers, door trim panels, wheels, tires, and more.
It can be very interesting or it can drive you crazy. For some people it's both.
Have fun!!!!
Regards,
Alan
To Devaluation effect
Old Aug 25, 2010 | 07:03 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Hi d,
Have fun!!!!
Regards,
Alan
I bet it's a rare find, to find one with EVERYTHING right. I would assume it would really have to be a barnyard find. To have water pumps and all else still original. Thanks for the answer!
Old Aug 25, 2010 | 07:19 PM
Corey_68's Avatar
Corey_68
There is nothing wrong with a sleeved block many race cars have them and some race team sleeve brand new blocks for the beginning.
Old Aug 25, 2010 | 08:11 PM
BBCorv70's Avatar
BBCorv70
OK
I don't think I've ever seen a sleeved block nor do I know anyone who has had it done. Could be expensive I guess, not done unless there's good reason to save the block? Other than race motors...
