Options info '68
Sep 17, 2010 | 07:07 PM
St. Jude Donor '09-'11-'12-'13-'14
Options info '68
I've looked all over the net for the location of the options tag on a '68. I've found all the option codes online just can't find the tag on the car.
I'm new to C3's, sorry.
Thanks for helping an old guy.
Sep 17, 2010 | 07:14 PM
2024 C3 of the Year Finalist - Unmodified
No such thing. Without original documentation, your are S-O-L. The factory never kept build records either. Nice, huh?
Sep 17, 2010 | 07:17 PM
Quote:
Originally Posted by
Faster Rat
That's kinda what I thought.
I'm looking at a car that could have been a big block at one time. Any tipoffs as what to look for?
Sep 17, 2010 | 07:20 PM
If it's a small block, locate the partial VIN# on the front pad right above the water pump. If it matches your cars Vin, then it's an original SB
Sep 17, 2010 | 07:26 PM
2025 C2 of the Year ('63 and '67) Finalist - Unmodified
C2 of Year Finalist (appearance mods) 2019
Usually BB had 7 leaf springs; small block had 9 leafs.
Sep 17, 2010 | 07:29 PM
If it's a small block, locate the partial VIN# on the front pad right above the water pump. If it matches your cars Vin, then it's an original SB.
The engine isn't original so no help there.
I'll be under it tomorrow so I'll take a look.
Thanks for the help.
Sep 17, 2010 | 07:30 PM
Does it have a rear sway bar?
Sep 17, 2010 | 07:31 PM
JimE
I'll know tomorrow.
Sep 17, 2010 | 07:35 PM
claysmoker
The closest you'll get to an options tag is a sheet of paper stuck to the top of the gas tank. Occasionally they're still in readable shape.
Sep 18, 2010 | 03:07 AM
claysmoker
A couple of other items may suggest it was a big block. The radiator was 27 1/2 wide at the core. They had a rear sway bar and caps retaining the u-joints on the differential rather than u-bolts. Any of this could have been changed, no guarantee it's original.
Sep 18, 2010 | 08:32 AM
Hi,
I've always thought that in the 68 model year the only cars with the 7 leaf springs were cars equiped with the optional F-41 suspension. I believe that both sb and bb cars had 9 leaf springs as standard equipment.
Regards,
Alan
Sep 18, 2010 | 01:12 PM
1969RAY
All BB had 9 leafs. BB and SB had 7 leafs if F41 was ordered. 9 or 7 leafs had nothing to do with the engine size.
Sep 18, 2010 | 01:32 PM
What about the 'yellow' and 'red' line points on the tachometer? Were those values unique for big block engines? If so, that could help the poster determine what the car was originally built with.
Sep 18, 2010 | 02:08 PM
7T1vette
What were the yellow and red line values for small blocks and big blocks. Anybody have a listing? Curious..
Sep 18, 2010 | 03:20 PM
2025 C3 ('68-'73) of the Year Finalist - Unmodified
BBCorv70
check the redline on the tachometer
427/390 @ 5600
427/400 @ 5600
427/435 @ 6500
BB'S ALSO HAD 2 1/2" EXHAUST, & U BOLTS ON THE 1/2 SHAFTS
Sep 18, 2010 | 03:27 PM
427SIXPACK
427/390 @ 5600
427/400 @ 5600
427/435 @ 6500
U Bolts? Thought they were caps in place of the U Bolts..
Sep 18, 2010 | 04:06 PM
I 'believe only the 68 BB as OE had 2 1/2 exhaust, and all the others are 2"...
Sep 19, 2010 | 02:34 AM
Hi
If there is only 1 fuel line ( no return line ), then it was a BB as well.
Only BB run the Holleys.
Except for the 390 HP BB version, had 2 fuel lines.
As far as I know, no SB had only 1 fuel line.
Rgds. Günther
Sep 19, 2010 | 10:34 AM
OK, so I bought it. It's not a BB car and never was darn it. But I think it has potential of being a pretty nice car without a lot of work.
Sep 19, 2010 | 11:40 AM
Looks nice! post some more pics. Looks like you got one of those rare coupes! (Check the numbers, coupes are relatively rare for 68)
