Wheel well height?
Old Sep 21, 2010 | 10:30 AM
jbaron's Avatar
jbaron
2017 C3 of the Year Finalist
Default Wheel well height?
Can anyone tell me the stock height of a '74 (with and w/o air)at the front wheel well when new. I can't seem to find it.
Old Sep 21, 2010 | 11:51 AM
7T1vette's Avatar
7T1vette
There is no spec for the height of the wheelwells. All the height specs are to the frame. The body, then, just mounts to the frame.
I do not have the '74 specs, but they can't be much different than for '71. The most relevant dimensions for what you are doing are the "J" and "K" measurements, from ground [level] to the underside of the frame at the front and back jackpoints, respectively.
"J" = 7-3/4" (+/- 3/8") with A/C ; 8-1/4" (+/-) without A/C
"K" = 7-3/4" (+/- 3/8") with A/C ; 8- " (+/-) without A/C
Your running height will appear to be too large if you put series 60 (or thinner) radial tires on the car. The '74 cars came with R70 series tires.
Old Sep 21, 2010 | 12:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
What are you wanting to do? The assembly instruction manual (AIM) has a diagram showing the frame measuring locations and a chart listing what the dimensions should be for cars with various options combinations.
Old Sep 21, 2010 | 12:22 PM
jbaron's Avatar
jbaron
I want to lower the front about 1 in. from where it sits now. I have original springs(witch have probablyweakend over the years).
So, I don't know if I need to lower 1 or 2 in. from stock height to get 1 in. lower than it sits now. Does that make sense?
Old Sep 21, 2010 | 01:21 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by jbaron
...Does that make sense?...
Yes. Make your measurements of frame height per the AIM. That will tell you whether your stock springs have settled a bit, how much, and give you a starting point for the replacement springs you want.
Old Sep 21, 2010 | 06:46 PM
Alan 71's Avatar
Alan 71
Hi jb,
The AIM does contain a sheet titled "TRIM HEIGHTS". UPC 6, Sheet A-12, in my 71 AIM.
The dimension for the distance from the ground, through the centerline of the front wheel, to the wheel arch is 27.91", average.
The size of the tire on the car affects this dimension. In 71 cars had F70-15 tires. The amount of air in the tire affects this dimension too.
I hope this gives you a start.
Regards,
Alan
Old Sep 21, 2010 | 07:24 PM
7T1vette's Avatar
7T1vette
Alan...
In my '71 AIM, that chart is on UPC 0, Sheet A-12. It does have Dim. "P" & "R" for the front and rear wheelwell opening height.
Old Sep 21, 2010 | 07:40 PM
jbaron's Avatar
jbaron
Thanks guys,
Mine sits at approx. 28 in. Guess my springs really haven't settled much. So I should be able to order 550 springs and get a 1" drop.
Jim
Old Sep 21, 2010 | 07:52 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Here are the factory trim heights for '74. Note that non-OEM spec tires will affect J and K (trim), or any other measurement referenced to the body.
Old Sep 21, 2010 | 08:04 PM
RxForPain's Avatar
RxForPain
It is my understanding as well that the ride heights are suppose to include having a full tank of gas and a spare tire in place. Someone correct me if I am wrong.
Old Sep 22, 2010 | 10:49 AM
7T1vette's Avatar
7T1vette
I think that is correct. No passengers, but full tank and spare.
Old Sep 22, 2010 | 11:30 AM
Easy Mike's Avatar
Easy Mike
Read the CURB WEIGHT note on the AIM page.
To Wheel well height?
