Im sure we all have them to varying degrees....but I wonder...Whats the most expensive tool you have bought that gets the least amount of useage.
I have Brake caliper pistons tools and never compressed the first piston with them, a steering wheel removal kit that ive never taken out of the box and several electrical testing tools that never have been used to test a wire.....but the most $$ one is a auto rotisserie. I bought it, the corvette subframe and almost every accessory they had and have used it only once....to lift my C3 off the frame and once to hold the body while I was painting it....Now it just sits there and collects dust...
a 12ton hydraulic gear puller that I used during my t arm rebuild. I will get some more use out of it when I do the front end but that's a while away. 200 hundred bucks but it can double as a mini press too.
I have a rather expensive set of crow foot wrenches (sockets?) that remain untouched, A set of those sorta wide, "U" shaped box wrenches. I used one of them once to get at a tricky transmission bolt, a harmonic balancer puller, also used once a thousand years ago, and the queen mother of them all is an Inch Lb. torque wrench...silly thing.
Someone said that "The most expensive tool is one that gets no use".
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
I have a distributor wrench that I bought and shortly after started down the LS path. So that wrench will be collecting dust for years to come. I do have a steering wheel puller and that tool to compress the spring inside the column with I have used a couple of times but it has been years. I also have a couple of timing lights that will never be used on the corvette again. As far as that goes, on any car at my house at this point.
I agree with the crowfoot wrenches, but when you need them, you NEED them ...and you're glad you have them. I have some GearWrench ratching end wrenches. These look cool but I never use. Not that practical. Nothing beats a good, quality open/box end wrench IMO. I've got a lot of tools that I seldom use, but when I need it, it's good to have. I have a new saber saw in the box that I never use ...and an almost new biscuit joiner that I just HAD to have that I have only used a couple times. Coulda done w/o that. Fortunately most of the tools I seldom use I managed to buy at garage sales, Harbor Freight, or nicely use at pennies on the dollar. So I don't feel that guilty.
OTOH, I have a Harbor Freight mini-lathe that I was concerned would fit into this category but I use it a lot actually. Way more than I had anticipated. Great little tool to have.
Isnt that funny...i have some flex head gear wrenches that i probably use more than anything. Funny how some of us use somethings that others never pick up....
Timing lights....yep, I have couple of those and only use them every now and again.
I agree. I have a few buddies that swear by them. It's just me..
I don't know about "expensive", but one of the coolest tools I bought (and have only used once) was a 'broken tap extractor'. I didn't even know such a tool existed. But, it was worth its weight in gold as I removed the broken tap from my wiper door (after I already drilled to remove the broken bolt shank!). Talk about your "double-decker" problem....
[P.S. Always use a sharp, titanium-coated tap to put new threads into an aluminum (or pot-metal...I'm not really sure) wiper door.]
