Thoughts on car
Old Oct 4, 2010 | 01:58 PM
KNIPPS's Avatar
KNIPPS
Default Thoughts on car
I am not familiar with the C3 neighbor hoods.....was seeking thoughts on this car thanks...
http://cgi.ebay.com/ebaymotors/ws/eB...67923997#v4-38
Old Oct 4, 2010 | 04:11 PM
Alan 71's Avatar
Alan 71
Hi K,
The car looks interesting in the pictures. It's extra value is in the LT-! option.
I think the big questions that aren't answered without an informed inspection of the car are... was it an LT-! when it left St. Louis, how many of the parts are that made it an LT-! are still on the car, and how original is the rest of the car?
Regards,
Alan
PS: It's curious that there's not a picture of the stamp pad.
Old Oct 4, 2010 | 05:23 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
Originally Posted by Alan 71
Hi K,
Regards,
Alan
looks like a lot of information regarding "originality" is missing. at the very least i would want to make certain it left the factory that way and isn't a clone. next would be to at least check the casting numbers to see if the engine, trans and rear end are appropriate date wise. a qualified independent appraisal should also be considered if you are a serious "buyer". they will check all the above and more.
Old Oct 4, 2010 | 08:43 PM
71 Green 454's Avatar
71 Green 454
You might also want to see what the owner posted on the C3 registry.
http://www.c3registry.org/index.php?...10-05&uid=9648
Old Oct 6, 2010 | 05:28 PM
KNIPPS's Avatar
KNIPPS
Default Front pad
Can someone look at the pad in the listing and give me their opinoin on it...thanks
Old Oct 6, 2010 | 06:21 PM
Alan 71's Avatar
Alan 71
Hi K,
The surface of the pad is very pitted. In the picture I don't see any sign of broaching.
The pits seemed to have been pushed down into the valleys of the letters as though the pad was stamped after it was pitted With the pad so pitted wouldn't the digits and letters be less distinct.
PLEASE REMEMBER....only ONE person's thoughts.
Regards,
Alan
Old Oct 6, 2010 | 09:19 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
That stamp pad looks really bad but I am definitely no expert. I have never seen the important engine date stamp suffix letters (CKY) to be so crooked and spaced so far apart...they appear to be outside of the gang...very suspicious. Is that the correct beginning of the VIN derivative (12S5112??) for a '72 LT-1 with VIN 1Z37L2S511275 as corrected by the seller? What happened to the last three numbers of the VIN derivative? They are faint or missing altogether. Combine that with lack of broach marks and the pitting that Alan mentioned....
This car requires some serious scrutiny before any LT-1 money changes hands.
Old Oct 6, 2010 | 09:33 PM
Mark G's Avatar
Mark G
I've read a few articles in magazines and books about how slopy some of the pads were stamped from the factory and mistake were not uncommon. ..
Mark G
Old Oct 6, 2010 | 09:46 PM
BBCorv70's Avatar
BBCorv70
If it were a restamp I'd think the stamper would have done a better job getting it straight rather than attract attention. The stamp which would have been done at St Louis looks much straighter. The crooked one is the one which would have been stamped at the engine plant? So far as rust pits go I'd think rust would settle in the valleys of the letters as well as on the pad. If it were restamped I speculate the compression of the metal during the stamp may obliterate rust pits..
Old Oct 6, 2010 | 10:01 PM
427SIXPACK's Avatar
427SIXPACK
2025 C3 ('68-'73) of the Year Finalist - Unmodified
I dont like the crookedness of the important part of the stamp........but i must say it looks like it's ok.........letters / numbers appear same size, but there is entirely too much rust on the pad to see any broach marks, it could have been restamped a very long time ago & then the rust came to make it look as it does now. But I also dont think a very long time ago, or the time it would take to rust the pad like that, noone cared to bother restamping..........it's also doing big money in my opinion, it's not "FRAME OFF" restored, the paint has been done, but it doesnt appear much else & not to clean under or in the engine bay................no documentation either, etc....& it's NOT A VERT......SO........I think $32K is a bit high.............
Old Oct 6, 2010 | 10:32 PM
joewill's Avatar
joewill
it is amazing that this car with that pitted and crooked stamp with the mis-alligned letters and incomplete Vin Derivative is currently bid at 32K.. nowhere is anyone asking the date code on the block.. and the paint on the pad? yes it is an LT1 due to the VIN#, but that stamp.. wow.
sure it is a 010 block, probably one of the most common blocks. easy to find anywhere and restamp.. but hard to find in the date range of this car. and this one has a pad that has probably been sitting in a junk yard for 25 years rusting away. thats why I say show me the casting date code.
of the 50 different definitions of numbers matching, this one even fails the one that most people use. how can this guy claim numbers matching?
But.. someone in the LT1 world knows this car to bid it to 32K.. or look at the bidders.. looks like a couple of people are the only one's bidding it up past 20K.
People will pay alot for 'unrestored' I suppose.. not me though..
Old Oct 7, 2010 | 08:26 AM
joewill's Avatar
joewill
" I will back the legitmacy of the vehicle and give a full refund if it's not a #s matching car I say it is"
a rather broad statement.. what will it take to prove this to the seller and to win in court and force him to refund when there is no absolute legal definition of numbers matching.. it is all heresay.
sure it is numbers matching.. the windshield pillar VIN# matches the VIN# on the title!
Old Oct 7, 2010 | 10:25 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by joewill
...I will back the legitmacy of the vehicle and give a full refund if it's not a #s matching car I say it is"...
Reading between the lines, it seems to me the seller is already aware of the out of the ordinary appearing pad stamp.
I would not purchase a car without seeing it beforehand, BUT I would certainly not purchase this car without having seen it.
Mark G: Pad mistakes were made, but were probably much less frequent than some of the self-empowered magazine writers want us to believe.
Old Oct 7, 2010 | 11:24 AM
7T1vette's Avatar
7T1vette
Nice car. But I wouldn't invest $30K+ in that car with that pad. It's more like a $25-27K car (max.), IMO. If it is a legitimate LT-1, the car should have some of the original documentation. Since it does not, very few folks will ante up the overcost for an 'original' LT-1 car. Perhaps there are some "suckers" on the hook at eBay.
Old Oct 7, 2010 | 11:35 AM
garage-ghost's Avatar
garage-ghost
Hi K,
I think the big questions that aren't answered without an informed inspection of the car are... was it an LT-! when it left St. Louis, Regards,
Alan
1Z37L2S511275 Serial number confirms it was an LT-1 when it left the factory.
Old Oct 7, 2010 | 11:40 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by garage-ghost
1Z37L2S511275 Serial number confirms it was an LT-1 when it left the factory...
BUT possibly not with the "LT-1" currently in it.
Old Oct 7, 2010 | 12:51 PM
garage-ghost
Ohhhh so true!!!
To Thoughts on car
Old Oct 7, 2010 | 12:55 PM
KNIPPS's Avatar
KNIPPS
Default Vin
Wow...I bet the guy stamping the VIN 38 years ago on a friday afternoon just before quitting time never thought his work would mean so much today!!!
Old Oct 7, 2010 | 02:19 PM
BBCorv70's Avatar
BBCorv70
Maybe somebody can track him down and ask him to verify this is the exact engine he had stamped? Get his sworn statement?
Old Oct 7, 2010 | 02:37 PM
Easy Mike's Avatar
Easy Mike
JohnZ says they cranked out about 5500 small blocks a day at Flint -- all types. Most of them shipped the same day.
Wow-eee
