vacuum gurus needed
Old Oct 7, 2010 | 04:11 PM
early71's Avatar
early71
Default vacuum gurus needed
After many trouble free years,wiper door quit last week.In 2-3 hours of poking around for obvious causes,I come up empty.Vac.relay is out,when I apply hand pump vac. to unit ,I can see movement at the end of it.I'm thinking it is bad.(original ) Any tests I can perform ?Actuator is new,and door can be opened by hand.Thanks crew...JC
Old Oct 7, 2010 | 04:20 PM
Alan 71's Avatar
Alan 71
Hi JC,
I've found the component testing and trouble shooting guide that 'Dr. Rebuild' wrote and sells is well worth the few $ it costs.
Regards,
Alan
Old Oct 7, 2010 | 06:56 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Originally Posted by Alan 71
Hi JC,
Regards,
Alan
100% Well worth the $4-5.00.
Old Oct 7, 2010 | 09:31 PM
7T1vette's Avatar
7T1vette
You really can't use one of those hand-operated vacuum pumps to do any 'significant' testing on a C3 vacuum system. It just doesn't provide enough volume (or anti-volume, I guess...) to make anything work. There are usually leakages that exhaust anything that pump might provide...even on good systems.
Old Oct 8, 2010 | 01:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Does the wiper door open/close with the override?
Old Oct 8, 2010 | 02:25 PM
early71's Avatar
early71
Default override
Mike,override does nothing,I'm not getting vac to relay and relay just tested bad.Seems the further I look,more problems I find....JC
Old Oct 8, 2010 | 03:32 PM
1971corvette's Avatar
1971corvette
the hand pump is good for testing individual parts one at a time
,to test the system as a whole, NO the pump does not provide enough vacuum as ststed above,thank you 7T1
Old Oct 8, 2010 | 04:18 PM
dntoearthman's Avatar
dntoearthman
Default Vacum pump
I do not have a good pump but am planning on building one from an AC compressor.
I adapted an air hose to main vacum line on my vette, ran it out the garage to my Lexus engines vacum port. works great for short term testing.
To vacuum gurus needed
