1972 Coupe Electrical Issue
Old Oct 11, 2010 | 01:13 PM
oakley_77's Avatar
oakley_77
Default 1972 Coupe Electrical Issue
Hey guys/gals,
I have a 1972 Corvette coupe (base 350/auto).I had a strange issue the other night after an hour and a half cruise.
It was getting dark so I pulled up the lights and the car simply died. Good thing I was just cruising at 15 mph.
When I pulled on the headlight switch, I lost all electrical power to the interior and the motor eventually stalled after a few seconds. The power came back after 30 seconds to a minute when I was in the hood touching the 3 starter wires. I was then able to get in the car, pull up the light on high beam again and they worked just fine. I can't reproduce the problem all the time. Sometimes it shuts off, sometimes it works great. All the wires are bolted tight to the starter.
Any ideas where I can start looking for the issue?
Thanks again.
Oakley_77
Old Oct 11, 2010 | 01:22 PM
7T1vette's Avatar
7T1vette
Probably a main battery cable or grounding cable issue. Check the wires and connections on the battery cables. Also check the grounding cable from starter mount to motor mount (right side).
Old Oct 11, 2010 | 07:26 PM
oakley_77's Avatar
oakley_77
Thanks for the reply 7T1vette.
I checked my cables going to the battery and going to the starter. They all look like they're in good shape. So, I started the car with the headlights on and moved the wires. The motor ran perfectly.
I was wondering if it could be the headlights switch itself? I am almost certain that the engine only stalls when I turn on the headlights and they are set to high beams?
What do you guys think?
Old Oct 11, 2010 | 07:35 PM
7T1vette's Avatar
7T1vette
I don't believe there is any way that the motor will stall due to any defect in the headlight switch (unless the dash catches fire and you turn off the key). It most likely is a wiring problem in the area of the starter motor.
Tug on the fusible links to see if they are still intact. (If a fuse-link is 'toast', all that's left will be the insulation...no wire.)
Old Oct 11, 2010 | 07:47 PM
oakley_77's Avatar
oakley_77
OK. I will certainly check that. Can you tell me where the fusible links are located?
Old Oct 11, 2010 | 08:44 PM
...Roger...'s Avatar
...Roger...
Possible bulkhead connector shorting.
Don't forget to check that pesky neg battery cable to chassis connection.
Old Oct 12, 2010 | 06:13 AM
oakley_77's Avatar
oakley_77
Thanks ...Roger... I will give it a try...
I thought I had read that there was a circuit breaker somwhere in the circuit. Is this true or am I thinking of something else?
Old Oct 12, 2010 | 06:45 AM
...Roger...
Yes there is a breaker in the HL switch , fusible links as 7T1 mentioned and fuses in the fuse box.
The fuses won't come back , the fusible links will not come back.
Old Oct 12, 2010 | 12:03 PM
jaki30's Avatar
jaki30
Default High Beam lever
Is the High Beam lever interfering with the ignition switch rod in the column?
Old Oct 12, 2010 | 02:16 PM
oakley_77's Avatar
oakley_77
I can check that tonight...Would this cause this issue?
Old Oct 12, 2010 | 02:38 PM
#s matching 72's Avatar
#s matching 72
I think the car in question is a 72 and there is no "High Beam Lever" on the column, it's a foot operated switch on the floor near the left kick panel.
I wish I had a real fix for the problem, intermittent problems are hard to trace.
Old Oct 12, 2010 | 03:25 PM
mobjack68's Avatar
mobjack68
One thing that might help....if you are under the hood or in the car twisting wires around??? use a flashlight/worklight to put your hand on the wires.....then douse the light...jiggle away....look for sparkies....nothing there?? worklight back on, grab somewhere else...
While you are looking, search for wires with insulation disturbed, either from heat, vibration or mechanical removal....
Old Oct 14, 2010 | 12:08 PM
jaki30's Avatar
jaki30
DUH! My bad. I meant to say if the issue happened with the use of the tilt lever, it may have interfered with the rack and rod to the ignition switch.
Old Oct 24, 2010 | 03:13 PM
oakley_77's Avatar
oakley_77
Thanks for all the replies.
I am currently waiting on a new headlight switch.
I hope this fixes the issue. But, for some reason, i have a feeling that it's something else.
I searched pretty much everywhere to see if anyone else experienced this issue but I seem to be the only lucky one...haha
To 1972 Coupe Electrical Issue
