Carpet install -- please help
Old Dec 18, 2010 | 12:53 PM
pwsusi's Avatar
pwsusi
Default Carpet install -- please help
Well, i hit an unexpected problem while replacing my carpet. One of the screws for the footman loop has no head and is stuck. I've tried needlenose pliers and can't get it out. Any suggestions?
[IMG][/IMG]
Old Dec 18, 2010 | 01:15 PM
Alan 71's Avatar
Alan 71
Hi pws,
I think I'd soak it with rust buster of some kind overnight, and then grab it with vise-grips. I don't think you can get a tight enough clamp with regular pliers.
Soak it well before you try so you don't break it off right at the fiberglass under body.
I might also try tightening a bit before loosening it.
Good Luck!
Regards,
Alan
Old Dec 18, 2010 | 01:18 PM
pwsusi's Avatar
pwsusi
Thanks...i'll give it a shot.
Old Dec 19, 2010 | 09:47 AM
wydglydrydr's Avatar
wydglydrydr
If you have a dremel tool, flatten two sides and put an adjustable wrench on it. Soak it well first, as Alan suggested.
Old Dec 19, 2010 | 10:05 PM
pcmaz's Avatar
pcmaz
3rd Gear
Cut it flush with the floor and drill it. Thats the fastest way. Good luck!
Old Dec 21, 2010 | 02:04 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
I agree with Alan; Vise Grips would get my vote.
To Carpet install -- please help
