Engine bay repaint..what color?
Old Dec 24, 2010 | 09:36 PM
BryanB75's Avatar
BryanB75
Default Engine bay repaint..what color?
Curious as to what color some of you have repainted your firewall and fenderwells. That's next on my list before the new motor goes in.
Post your pics
Old Dec 24, 2010 | 09:49 PM
Go Vette Go's Avatar
Go Vette Go
2024 C3 of the Year Finalist- Unmodified
St. Jude Donor '10-'11, '15, '19
I used a semi gloss black - it dries to about a satin black.
Old Dec 25, 2010 | 08:24 AM
3JsVette's Avatar
3JsVette
What's the theme of the car? If it's stock semi gloss black or "under hood black". If it's custom you may want to consider the body color or a complimentary color. If it's a road race car many use light gray. Just keep in mind anything other than the stock semi gloss black will be much harder to maintain.
Old Dec 25, 2010 | 10:01 AM
Alan 71's Avatar
Alan 71
Hi,
I think that nothing shows off Chevrolet orange like semigloss black.
Regards,
Alan
Old Dec 25, 2010 | 12:55 PM
garage-ghost's Avatar
garage-ghost
Originally Posted by Alan 71
Hi,
Regards,
Alan
Totally
Old Dec 25, 2010 | 01:20 PM
U17's Avatar
U17
Fenders ect white.. easier to chase leaks and helps reflect light up in there... Firewall black ..
Old Dec 26, 2010 | 06:44 PM
MalibuVLX's Avatar
MalibuVLX
semi gloss/satin black. Gloss is too shinny and shows all the imperfections. Flat is too dull and no luster at all.
Old Dec 26, 2010 | 06:50 PM
markids77's Avatar
markids77
If you do it black, try some John Deere "Blitz Black". It is a bit more than Krylon etc. but applies beautifully and dries to a perfectly uniform satin sheen... no "tiger stripes" like some other finishes. It is quite durable and heat resistant for a spray bomb product as well; good stuff.
Old Dec 26, 2010 | 08:32 PM
Vette5.5's Avatar
Vette5.5
I normally use Rust Oleum semi gloss black with pretty good result's. It's pretty good stuff, and since normally needing way more than first planned, nice to know I can just run down to the corner hardware for more in a pinch.
Old Dec 26, 2010 | 09:08 PM
ICEMAN59's Avatar
ICEMAN59
Check out my photos and you can see pics, I did mine in semigloss black
http://forums.corvetteforum.com/phot.../ppuser/164052
Old Dec 26, 2010 | 09:11 PM
C3 4ME's Avatar
C3 4ME
I did mine Krylon 1613 Semi Gloss black, which is no longer available. Semi gloss black very close to factory original.
Old Dec 26, 2010 | 09:32 PM
BryanB75's Avatar
BryanB75
Mark,
Thanks for reminding me about that. I had read about it and saw pictures of it after it dried. Looks pretty nice. I might want to use that for my frame
Old Dec 26, 2010 | 11:24 PM
vettebuyer6369's Avatar
vettebuyer6369
Are you doing a full engine compartment restoration...
or a quick detail?
Old Dec 27, 2010 | 12:46 AM
eastltd's Avatar
eastltd
Try some Mar-Hyde.
This is black satin
http://solutions.3m.com/wps/portal/3...beS38K155C5Rgl
Old Dec 27, 2010 | 11:06 AM
72ragtop's Avatar
72ragtop
I used Quanta's semi flat black on my engine compartment and underhood.
Old Dec 27, 2010 | 05:18 PM
twinpack's Avatar
twinpack
Originally Posted by eastltd
Try some Mar-Hyde.
This is black satin
Nice and clean, under stated look.
Old Dec 27, 2010 | 06:42 PM
Alan 71's Avatar
Alan 71
Hi,
I believe the original Krylon #1613 is still being manufactured but is only available from 'industrial' suppliers.
I bought a new supply a couple months ago from a photography supply house in California.
Although I like the Quanta and the Blitz blacks I still like Krylon the best.
The way I read the Krylon label it's lacquer.
Regards,
Alan
To Engine bay repaint..what color?
Old Dec 28, 2010 | 07:30 AM
twinpack's Avatar
twinpack
Hi,
Regards,
Alan
Alan, that looks great!
Old Dec 28, 2010 | 07:52 AM
U17's Avatar
U17
White fenders, black firewall .... Name:  GTG_2641.jpg
Old Dec 28, 2010 | 03:55 PM
68/70Vette's Avatar
68/70Vette
Used Eastwood's black paint for the firewall. The splash shields - the triangular like shaped shields between the frame and firewall, I painted Ford Engine Grey. It's so dark down there, it's good to have some grey colored surfaces to reflect light so you can see.
Also, the steel stone sheilds at the lower left and right hand sides, also in grey. (1968 and 1970)
