Should I do my own interior?
Old Feb 13, 2011 | 08:19 PM
Ret.Horsecop13's Avatar
Ret.Horsecop13
St. Jude Donor '11-'12-'13-'14
Default Should I do my own interior?
I want to do my interior (door panels, carpet and seats) Is this something I can do myself? What tools will I need? I know there will be people that say "Yes you can do it all by yourself" but are these the same people that say I can pull my engine out and rebuild it?(which I can't) How hard is it? I am not someone who would take on a HUGE project,but I think I can do an interior. Any thoughts? Any novice ever take this on? Thanks!
Old Feb 13, 2011 | 09:01 PM
mds3013's Avatar
mds3013
Hi Ian. I would not try to recover the seats myself. From what I know about this they are not easy to get right. The rest is pretty straight forward. The carpet on the storage doors can be difficult also. Ck. with Willcox they had a special on interiors with seat recovering included. It may have expired by now. Good luck with it, mike...
Old Feb 13, 2011 | 09:25 PM
chstitans42's Avatar
chstitans42
TheCorvetteBen
Too bad your not in DFW. Id restore your interior for you. That is my favorite thing to do on these cars! but what Mike said is true. Get the seats done by a profesional, and you can tackle the rest. Willcox is the best vendor I think for interior pieces
Old Feb 13, 2011 | 10:32 PM
donnie1956's Avatar
donnie1956
I am in the process of finishing my interior on my 78. It was not that difficult for me. That being said I installed car stereo's in the early 80's so got to be pretty good at taking interior pieces apart and replacing. I completely gutted my car and replaced or repaired everything.
Old Feb 13, 2011 | 11:50 PM
johnt365's Avatar
johnt365
You can do it yourself but you probably will not enjoy it. The seats will be tedious. Look at the major suppliers catalogs for a kit with the tools needed for this job.
Carpet is easy enough to do yourself but be very careful. Its one of those deals where its easier to cut off then to add on.
I have never done it before and think I did a pretty good job for my first time.
Old Feb 13, 2011 | 11:57 PM
procketus's Avatar
procketus
C4 of Year Finalist (appearance mods) 2019
2017 C4 of Year Finalist
Are you talking about doing a custom interior? Or a factory look?
Did mine last summer, took a whole day to strip the interior(minus dash) and install all new parts.
Seats with tracks
Carpet
Console
Door panels
Steering wheel
piece of cake.
No special tools really.
Old Feb 14, 2011 | 12:07 AM
oldsarge's Avatar
oldsarge
It can be a bit of work, but you can do it, if you have the patience and a little talent, I did my own, with mostly new parts and some parts I dyed. I also redid my own seats, frame refurb, new foam and new leather.
Old Feb 14, 2011 | 12:42 AM
7T1vette's Avatar
7T1vette
Refurbishing the interior is not a difficult task. You need to have a place to disassemble it and store the parts plus workspace for some repair/rebuild work. If you have above average DIY capabilities, you should have no trouble. The interior is put together with screws; the trick is to remove them [and reassemble them] in the right order. That is why you must have a copy of the AIM (factory Assembly Instruction Manual) for your year car.
You need to disassemble the interior...carefully so you don't damage/break any 40 year old parts. Then you need to clean and inspect all of the parts. ALL of them should be reused, or repaired and reused, unless they are unsalvageable. This is because of cost for new parts, but also because 'new' parts just don't fit right many times. Then, all of the vinyl/plastic parts need to be re-dyed using vinyl dye--NOT PAINT!!! SEM ColorCoat is great stuff, easy to use and will make your interior look just like 'factory new'.
Whichever way you choose to go, good luck.
Old Feb 14, 2011 | 02:29 PM
milo30's Avatar
milo30
Farm out the seats and do the rest yourself. Pull up some threads of people who have done the interiors. A ton of them out there and you'll be able to judge for yourself. You could probably do the seats too but they are probably the hardest part of the interior so pay someone to do them and get them done right.
Old Feb 14, 2011 | 02:42 PM
markids77's Avatar
markids77
I say roll your own. I bought seat covers and an installation kit for my 77 and the only specialty tool I needed was a set of hog ring pliers. I did my seats in a day, cold start first timer. The carpet install is going to be much the worse of the two jobs... gutting the interior is a major pain; but requires only normal tools and some patience (and good photo documentation and a whole box of ziplock baggies).
Old Feb 14, 2011 | 02:51 PM
Muddywaters's Avatar
Muddywaters
I did my interior...Joannd installed the Dynamat. I did hire out the seats...next go around (project) I'll tacklet he seats too. Go for it! Muddy
Old Feb 14, 2011 | 05:07 PM
Ret.Horsecop13
Thanks for all the replies! I think I will give it a go. Whats the worse thing that could happen? Thanks again!
Old Feb 14, 2011 | 05:30 PM
Alan 71's Avatar
Alan 71
Hi,
I think it's pretty rewarding work.
For the carpet.... you need to avoid the urge to cut until you're absolutely sure.
For the seats... leave one intact so you can use it as a reference for the first one you do.
For the door panels.... pray that they'll fit.
Regards,
Alan
Old Feb 14, 2011 | 06:20 PM
Ret.Horsecop13
As always Alan, I can't believe your car is 40 years old! It looks like it is on the showroom floor! If mine could look 1/2 as good as yours I would be ecstatic!
Old Feb 14, 2011 | 08:43 PM
markids77's Avatar
markids77
A late thought... spring for new seat foam. I recycled my original, and beefed it up with some batting, but my covers still dont sit as smooth as Alan71s. If I were to do it again I would replace since the foam tends to shrink/compress as it ages.
Old Feb 14, 2011 | 09:40 PM
oldsarge's Avatar
oldsarge
I would say get new foam, while you have them apart, you will regret it, if you don't !!!
Old Feb 15, 2011 | 08:50 AM
Alan 71's Avatar
Alan 71
Hi,
I first put the seat covers on using the original foam because I'd read that new foam made the seats look too puffy' compared to the typical originals.
The covers were about as wrinkly as my 66 year old butt.
So I took them back off. Got new foam and put them back on. I used a hair dryer and LOT'S of time to get them smooth. They are a bit 'puffy'.
I tried the hair dryer on my butt but it didn't seem to help.
Regards,
Alan
To Should I do my own interior?
Old Feb 15, 2011 | 10:19 AM
Bill420247's Avatar
Bill420247
I also am getting ready to redo my interior on my 80. I just got it last month and the interior is the only thing that needs redone.
I went back and forth on doing it myself or having it done. For one I don't want to pay to have it done and two I think I can do all the work myself.
And so I don't have to install the seat covers I am just going to get the new seat foam with the covers already installed. Just like previously said everything else is just taking it apart and putting it back together.
I have never done work like that before but I am good at DIY stuff so I am going to give it a shot. I will take before and after pics to post on here.
Thanks for everyones input and helping me decide to tackle it myself!
Old Feb 15, 2011 | 12:18 PM
Alan 71's Avatar
Alan 71
Hi Bill,
I think the thing I learned most of all while working on my car is to not feel bad if you don't get it the way you'd like the first time.
I can probably count on one hand the things that didn't need to be redone at least once.
So give it a try!!!!
Nothing beats working on an old car. (Well, maybe one or two things do!)
Regards,
Alan
Old Feb 15, 2011 | 02:03 PM
GPGG70's Avatar
GPGG70
DIY!! Take your time. If your not sure about something take pictures and post them here for help. Try not to set a finish date. It's finished when it's finished.
I rebuilt my seats and have never rebuilt seats prior to that and they came out perfect if I say so my self, and I was able to pat my self on the back for re-building them.
