Seats.
Old Feb 15, 2011 | 10:20 AM
markids77's Avatar
markids77
I think the rods in question are those that go through the wire loops which are stuck through the foam. They hold those loops against the foam backs, and provide the "crease" in the upholstery. The rods are also hog ringed to the seat springs keeping the cushions from moving around in use.
Old Feb 15, 2011 | 10:22 AM
7T1vette's Avatar
7T1vette
That's a pretty good description of the "wavy" rods and their purpose.
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
Originally Posted by Roma
Does someone can provide a link for a detailed describtion of the seatrestauraton for a 69'
I think this also interesting for others, also for me ;-)
Frank
Frank,
Do a google search for "corvette fever seat cover install." It will take you right to the link for the article with pictures. scroll the curser over the pics for the complete instructional paragraphs/captions. Good luck.
Terry
Old Feb 15, 2011 | 11:28 AM
Roma's Avatar
Roma
Originally Posted by HOOAH
Frank,
Terry
Thanks Terry,
this is even better then the Wilcox Describtion:
http://www.corvettefever.com/howto/c...ver/index.html
Best Regards
Frank
Old Feb 15, 2011 | 12:34 PM
HOOAH's Avatar
HOOAH
Thanks Terry,
Best Regards
Frank
Frank
The Wilcox doc you referenced is more of a parts listing which is very thorough whereas the fever article is a step by step "how to" article. In fact they (Wilcox) even mention that it is best to seek a professional installer to perform the seat recover.
Terry
Old Feb 15, 2011 | 12:44 PM
Roma's Avatar
Roma
Next week I try to perform the seatrecover. I hope it will not only be a try ;-)
Old Feb 21, 2011 | 02:15 PM
Roma's Avatar
Roma
I started redoing the Seats today. Disassembly of the Passenger Seat :
This is where I start :
This what I have :
Buttom and Back ready for sanding and paint
This is where my parts are from :
http://www.ecklers.com/corvette-seat...1968-1969.html
http://www.ecklers.com/corvette-seat...Product_Upsell
http://www.ecklers.com/corvette-seat...roduct_Related
https://www.paragoncorvette.com/p-35...ng-pliers.aspx
https://www.paragoncorvette.com/p-35...tion-tool.aspx
I hope to finish till Sunday
Regards
Frank
Old Feb 21, 2011 | 05:14 PM
dbeall1968's Avatar
dbeall1968
I sandblasted the bare frames that you are showing, then painted them with a rust converter, then black paint. They look like new. You are doing fine so far.
Old Feb 21, 2011 | 05:34 PM
Alan 71's Avatar
Alan 71
Hi Frank,
You CAN do it!
Don't rip anything by pulling too much, or stretching it too far.
Don't use a scissors unless you're absolutley sure you need to!
GOOD LUCK!
Regards,
Alan
Old Feb 21, 2011 | 08:49 PM
kdf1986's Avatar
kdf1986
I just finished the seats on my 72. The wavy rods were not in the seat installation kit I purchased. It had the hog rings, the S clips, 1/2", 1" and 3" clips and the long straight pieces for the seat bindings, but the wavy rods that go between the seat foam and the seats were not included.
I had to use the originals. If yours are missing then maybe a suggestion would be to call an auto reupholstery company to see if they have any for sale.
kdf
Old Feb 22, 2011 | 02:42 PM
Roma's Avatar
Roma
Here are some pics of my progress and a question at the end
Not NCRS-like but I am happy with it
Included in the kit are these hooks, but maybe to less of them
Which size should be located where ?
This is the bottom of the seat
with hooks, but I think I should only make it with the second smallest hooks ?
Any help available ?
Frank
Old Feb 22, 2011 | 06:21 PM
Roma's Avatar
Roma
I have it
The smallest ones are only for the BackSeat :
The Hook 2,3 and 4 from my pic are only for the ButtomSeat
I counted again and now I got enough. Its late here in Germany ,maybe thats the reason
Old Feb 23, 2011 | 12:07 AM
  #33
kdf1986's Avatar
kdf1986
hello
I think you got it right. The small hooks are for the seat back portion.
The bottom seat is tapered and the front of the seat is thicker than the back of the seat. So you will use 2 different sizes depending on how thick the seat foam is.
For the S clips on the bottom I turned the seat upside down, placed a towel on the springs and kneeled on it. This compressed the foam enough to get the S clips to clip onto the seat frame.
kdf
Old Feb 23, 2011 | 08:20 AM
  #34
7T1vette's Avatar
7T1vette
Just cut a piece of wire coathanger. Fold one end to make a "T" handle out of it; put a very short 120 degree bend on the other end to use as the 'hook' to catch the loose end of those clips and pull them through the foam. Then slide the 'wavy wire' through it to hold in place.
