Seats.
Old Feb 13, 2011 | 10:36 PM
Indiancreek's Avatar
Indiancreek
Default Seats.
I have a quick question for the interior guys. I am redoing my seats and they didn't have all the wave rods in them. Has anyone used something else or modified something else to use in their place?
Maybe bending some welding rod or something else.
Old Feb 14, 2011 | 12:09 AM
oldsarge's Avatar
oldsarge
Check with the aftermarket suppliers, I think they are available now. Or call Paragon Vintage Dept. they might have some.
Old Feb 14, 2011 | 12:33 AM
7T1vette's Avatar
7T1vette
Those wave rods are hardened...like springs. You can't just stick any mild steel wire in there for them. The aftermarket suppliers should have them for sale. Or you could get them at some Corvette swap meets or used part places.
Old Feb 14, 2011 | 01:51 AM
Indiancreek
Thanks, I looked at the site I got the seats from (Willcox) and didn't see them. I must be looking in the incorrect location. I'll try again.
Thanks again for the information
Old Feb 14, 2011 | 07:14 AM
ozzyrulesme's Avatar
ozzyrulesme
When u buy the seat kit . They come wither the hog rings. Got it from wilcox.
Old Feb 14, 2011 | 10:11 AM
jdp6000's Avatar
jdp6000
Not sure what year your car is but here is the link to Willcox for the 79-82. This is the kit you will need...it will get you to yh right Willcox section
http://willcoxcorvette.com/product_i...ducts_id=24477
Old Feb 14, 2011 | 12:36 PM
Indiancreek
I have the seat install kit. To be sure I wasn't missing something. I checked the boxes again as I haven't begun to attack that portion as of yet.
In the install kit, there are no wave rods, as a matter of fact, I have one wave rod, and there are no rods in the pack that are the same length as the one that I do have.
Is there a larger install kit? I didn't need hog rings as I use them in the shop on a regular basis and have a small bucket of them on hand.
Old Feb 14, 2011 | 01:31 PM
Roma's Avatar
Roma
Does someone can provide a link for a detailed describtion of the seatrestauraton for a 69'
I think this also interesting for others, also for me ;-)
Frank
Old Feb 14, 2011 | 02:35 PM
Alan 71's Avatar
Alan 71
Hi Frank,
Al Knock has a video that shows one of his people installing a set of seat covers. It's quite a help.
I found that leaving 1 seat with the old cover still on, so you have it to refer to, as you put the first set on, was a help, too. The bottoms are very easy, the backs are a bit more of a challenge.
Regards,
Alan
Old Feb 14, 2011 | 02:52 PM
Roma's Avatar
Roma
Thanks Alan,
looks like the video is not for free, I can't find it on their Webpage ?
But I just found a describtion on the Wilkox page
http://willcoxcorvette.com/instructi...help_70-78.pdf
Not for 69, but I think the difference is not so big
Regards
Frank
Old Feb 14, 2011 | 06:12 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
The wave rods in the seat bottoms and backs are springs. Back shown, bottoms are similar.
You need a replacement seat spring.
Upholstery bails and listing wires which are in the upholstery installation kit hold the upholstery material to the springs and seat frames.
Old Feb 14, 2011 | 06:55 PM
7T1vette's Avatar
7T1vette
The "wavy rods" are not shown in Easy Mike's photo. They are the wires that the seatcover retainer clips connect to. Eckler's (and many others, I'm sure) sells a "complete" Seat Cover Installation Kit which contains "all the hooks, clips, wires and hog rings you need for a complete installation" [about $35]. Also buy a cheap set of hog ring pliers and the seat cover hook installation tool [$5]; you only need them for 2 seats.
Good luck!
Old Feb 14, 2011 | 07:46 PM
eastltd's Avatar
eastltd
I believe the rods in question here are not part of the rebuild kit. At least they were not part of the kit I bought.
Check your old seat covers and reuse the old rods if they are still there.
Good luck!
Old Feb 14, 2011 | 08:09 PM
'75's Avatar
'75
Good luck!
I had to reuse the originals.
Old Feb 14, 2011 | 08:21 PM
Indiancreek
I have but one as the seats had been changed at least twice. I have the only remaining wave rod. It looks to be about the same hardness as a welding rod.
Wondering if the wave the entire length is needed. In someone's opinion would a wave just where it attaches to other wires be sufficient? I can make one from welding wire.
Old Feb 14, 2011 | 08:41 PM
dbeall1968's Avatar
dbeall1968
My kit did not have the wave rods, either. I was able to clean and re-use mine. I would post a wanted ad in the for sale section. I bet there are a bunch of them available from guys on this forum.
Old Feb 14, 2011 | 08:53 PM
markids77's Avatar
markids77
I understand why the wavy rods are wavy... the hog rings lock onto the wave and keep the rods from slipping. They are a royal pain to coax (yank) into place though. Some of mine were so rusted I used a length of old CB radio antenna I had in the shop, and simply crimped the rod a bit where the ring would go with pliers. Easy to install since it was smooth, it was free and is stainless so no more rust.
To Seats.
Old Feb 14, 2011 | 09:11 PM
Indiancreek
When I took the seats apart I found two full sets of seat covers. Out of two sets of seats, I had only one wave rod. Someone must have had a rough day mounting the second set of seats.
Old Feb 14, 2011 | 09:33 PM
oldsarge's Avatar
oldsarge
Talk to Paragon Vintage Dept. I do believe they have some out of their bone yard.
Old Feb 15, 2011 | 07:34 AM
Easy Mike's Avatar
Easy Mike
Originally Posted by 7T1vette
...The "wavy rods" are not shown in Easy Mike's photo...
We need a wavy rod pic. I thought he was referring to the springs.
