OEM vs. Poly
Old Mar 15, 2011 | 04:33 PM
Deacon Don's Avatar
Deacon Don
Default OEM vs. Poly
I'm gonna replace the bushings in my 72's rear suspension soon and I was wondering which is better - the OEM style or polyurethane?
Anyone have pro/cons of the two?
dd
Old Mar 15, 2011 | 04:52 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Both have drawbacks. Which is "better" somewhat depends on your priorities. If restoring original handling and ride comfort are what you're after, stick with rubber, but if reducing compliance to maintain more stable suspension geometry under heavy cornering loads without going to all-out racing components is a goal, then poly may be a better choice than rubber. However, IMCO poly isn't best suited to locations such as the rear camber struts and TA's which inherently travel in 3D's, so I suggest stepping on up to heim-jointed rear camber struts and thinking about spherical TA's out back should handling be a very high priority. Poly also requires proper periodic lubrication to avoid binding stiction (evidenced by squeaking).
That's my $.02. Some will recommend one over the other regardless of your purposes, and there are plenty of threads debating this ad nauseam if you care to search.
Old Mar 15, 2011 | 04:59 PM
Deacon Don's Avatar
Deacon Don
Interesting. I'll never race or attempt to drive the car beyond reasonable limits. It also won't see a whole lot of miles. I always thought poly was better primarily b/c it wouldn't deteriorate as quickly as rubber. Didn't know the other. I don't want a harsher ride and if they require maintenance, maybe I should stick with rubber.
Thanks,
Old Mar 16, 2011 | 11:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Deacon Don
...I don't want a harsher ride and if they require maintenance, maybe I should stick with rubber...
Old Mar 16, 2011 | 01:06 PM
24695bob's Avatar
24695bob
I only used Poly on one of my cars BUT replaced them in about one or two years with rubber... too stiff...too harsh..and too noisy for my tastes for what I used the car for (Saturday evening cruising mostly
Bob G.
Old Apr 10, 2011 | 09:45 PM
ncvettes's Avatar
ncvettes
How about rubber all around except the sway bar bushings and end links? That's my plan for my 72 frame off unless somebody has a better way.
Old Apr 10, 2011 | 10:46 PM
Mako72's Avatar
Mako72
2018 C3 of Year Finalist
I went with OEM style rubber at all locations for the exception of the front sway bar links and the rear leaf spring ends. Been very happy so far.
Old Apr 11, 2011 | 03:34 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
the poly bushings will definitely leave you with a much firmer ride than replacing them with the OEM rubber bushings. the upside to using poly if you can get comfortable with the ride is the poly last much longer than the rubber bushings do.
Old Apr 11, 2011 | 04:24 PM
7T1vette's Avatar
7T1vette
Yep. Rubber bushings only last 10-20 years, or so....
Old Apr 11, 2011 | 04:51 PM
Mike Ward's Avatar
Mike Ward
If not longer. People freak out when they see some surface cracking. It's meaningless.
Old Apr 11, 2011 | 04:53 PM
Corey_68's Avatar
Corey_68
Poly for me..
Old Apr 11, 2011 | 06:32 PM
ncvettes's Avatar
ncvettes
Originally Posted by Corey_68
Poly for me..
Damn Corey.... I lost my train of thought!
Oh yeah... now I recall. I'll be 90 or so when I'll need to replace mine. I wonder if it'll be any easier?
Old Feb 9, 2014 | 10:04 PM
nathanmargolis's Avatar
nathanmargolis
Cruising
Default Rubber vs. Poly
Rubber without a doubt for me.
Rebuilt the front end of my '69 five years ago with poly. End of last year noted that one of the A-frame bushings was all eaten up after 7K miles and replaced with rubber.
Today replaced the leaf spring bushings that were about four years ago as there were just crumbles left on the bolts from poly bushings. Went back to poly.
Many similar guys in our Corvette Club in Houston have experienced issues with poly. GO rubber for sure.
Nathan Margolis
Houston, Texas
Old Feb 10, 2014 | 08:31 AM
68L79's Avatar
68L79
My 68 still has 3 of the front A arms with the orig rubber....might need to change 10-20 to 45 or so...and I am in the middle of nothing but curves and mountains and lately very rough roads.
I agree poly is not good for ride quality.
Old Feb 10, 2014 | 08:33 AM
Easy Mike's Avatar
Easy Mike
Yo...this thread closed in 2011.
Old Mar 4, 2014 | 07:11 PM
Patro46's Avatar
Patro46
Street driven car? Rubber all the way except I'd go poly on my sway bars.
Old Mar 5, 2014 | 05:03 PM
twinpack's Avatar
twinpack
I am in the process of a full body off storation and researched this to death. Although it's a personal choice, I am replacing all rubber components with rubber components. Makes sense. Better ride, quieter ride, more original geometry, life cycle has already been proven. Of course I am bring my 68 as close as I can to original specs.
Old Mar 5, 2014 | 05:07 PM
twinpack's Avatar
twinpack
That's OK Mike we are all just enjoying ourselves.
Old Mar 5, 2014 | 05:56 PM
Snoopysvet's Avatar
Snoopysvet
To OEM vs. Poly
