Panel Replacement, Detectable?
Old Mar 25, 2011 | 07:59 PM
BBCorv70's Avatar
BBCorv70
Default Panel Replacement, Detectable?
Is there a way to tell if a body panel has been replaced, assuming it wasn't spliced. Any typical give away, something the factory did differently?
I ask mainly out of curiousity. Wondering at times if the rear panel on mine was changed. The bonding strips are there, no splices or other suspicious markings.
Old Mar 25, 2011 | 09:03 PM
markids77's Avatar
markids77
Compare the areas in question on both sides of the car. If the panel was damaged enough to warrant replacement, the inner suppports and splash shields likely needed repair as well. Since these areas do not show from the outside, shops might cut corners a bit on the cosmetics here and that will be the "tell".
Old Mar 26, 2011 | 12:13 AM
BBCorv70's Avatar
BBCorv70
The car is in winter storage right now (Northeast). I expect to be getting it back in a few weeks. I'll take a close look though I don't recall seeing anything unusual in that area.
Old Mar 26, 2011 | 08:18 AM
79L48's Avatar
79L48
Some hand molded replacement panels have a different texture on the back side than stock panels had. That may be one way to tell.
Old Mar 26, 2011 | 11:04 AM
Alan 71's Avatar
Alan 71
Hi BB,
SOME of the body panels had mfg's labels on them which would sure be a clue to originality.
Here's a picture of a label on the underside of the hood surround in the left wheel well. The date is 1-71, the first week of 71. I don't know why there are 2 labels. They are molded as part of the panel, not stuck on.
The body tub of my 71 has the same label dated 36-70.
Also, originally the areas where bonding strips were going to be used were 'roughed-up' (it almost looks like sand blasted) in order to increase adhesion. I'd look for signs of that too.
Some original bonding strips had numbers molded in to them. I'll get a picture.
Good Luck!
Regards,
Alan
Old Mar 26, 2011 | 12:35 PM
BBCorv70's Avatar
BBCorv70
Thanks all. I've wondered at times when people state the body has never been hit, how can you tell if the repair was done well?
I don't recall seeing any labels on any of my panels. I've had the body off and went over much of the underside.
Old Mar 26, 2011 | 01:06 PM
Alan 71's Avatar
Alan 71
Hi BB,
I think it is possible to determine a no hit body.
I do believe it's much easier to tell with an unpainted car. I 'think' I can see a difference in the bonding material used in St.Louis compared to what is used today.
The jig assembled front clips are really good, but I'd think it would be difficult to put a rear clip together without leaving a sign.
Regards,
Alan
Old Mar 26, 2011 | 01:43 PM
BBCorv70's Avatar
BBCorv70
Originally Posted by Alan 71
Hi BB,
Regards,
Alan
Hi Alan,
I agree, if the paint were stripped to bare glass it would expose most repairs.
Mine has never been hit since I've owned it, 28 years now. Question in my mind is what may have been done to it by past owners. Materials used would have been from the 70's to very early 80's.
Good looking body in those photos. I assume those are earlier pictures of yours. Thanks for sharing your photos, this thread and many before. They're quite interesting, helpful.
Old Dec 1, 2020 | 01:23 PM
vettemaan's Avatar
vettemaan
Is it just me or does that tread look a little used?
Old Dec 1, 2020 | 01:52 PM
vettebuyer6369's Avatar
vettebuyer6369
You are responding to a post from 9 years ago.
To Panel Replacement, Detectable?
