Pre-Drive routine
Old May 6, 2011 | 02:03 PM
A-Lo 71's Avatar
A-Lo 71
Default Pre-Drive routine
Just got my '71 and trying to get completely comfortable with the Corvette tendencies. Can anyone shed some light on their pre-drive routine??
Old May 6, 2011 | 02:11 PM
rcread's Avatar
rcread
Open the door, get in, shut the door, stab the gas pedal twice, insert key, push in clutch, turn key, drive.
Have fun!
Old May 6, 2011 | 02:19 PM
georgiaboy's Avatar
georgiaboy
With a 40 year old car ...... a little prayer couldn't hurt. I have a 78 and only a couple of trips were not round trips.
Old May 6, 2011 | 02:23 PM
Lon Wayne's Avatar
Lon Wayne
Default Vader Vette
Hey GroveCity i work in GroveCity.
Automatic or four speed??
I have an auto so I let it warm up so that when I kick it down it turns like 550 RPM and then your good to go. Lets hook up and go for a cruse.
St Marys in the morning.(9 to 3) Sat.5/7/2011
Old May 6, 2011 | 02:30 PM
24695bob's Avatar
24695bob
... I store my Corvettes each winter... and I run each of them thru my own check list every spring...
make sure battery is fully charged, change oil and filter, check ALL the other fluid levels (power steering brake fluids etc check tires (pressures and look for any signs of dry rot )... and check that my headlights turn signals etc are actually working...
then dust the cars off give them a quick coat of polish and ff I go...
Only takes an hour ...and I do NOT consider it work...
On all 3 of my C3's it is normal for me to have to bleed the brakes each spring and 2 of the three usually need power steering fluid ????
My C2 ..C4 and C5 get the same going over BUT the brakes etc are always fine...
Bob G.
Old May 6, 2011 | 02:32 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Put the key in the ignition and fire it up.
Check mirrors while watching oil pressure come up.
Put it in reverse and back out of the drive way.
Old May 6, 2011 | 02:33 PM
Derrick Reynolds's Avatar
Derrick Reynolds
St. Jude Donor '13-'15, '17 thru '22
Have fun!
If your car is in good shape, and you live alone, this works just fine. I try to remember to open the garage door before leaving for a drive, but I think that's the kind of mistake you only make once. But since there are 3 other people living at my house, and they tend to not think about the use of my car as much as I would when they put stuff places, I have added another habit to this routine. I press the door opener switch on the wall when I enter the garage, then walk along the passenger side, around the back of the car and back up the driver's side before getting in. This habit has saved me from backing over a wide variety of stuff that people have left behind or beside my car when I wasn't around.
Old May 6, 2011 | 03:21 PM
Schaggy's Avatar
Schaggy
1. Go to the safe deposit box and get out my lucky socks and pink/green wrestling mask.
2. Come home, light sweetgrass smudge and draw circle around corvette while chanting for good ju-ju.
3. Don lucky socks, wrestling mask and gold banana hammock.
3.5 Curl chest hair
4. Open garage door.
4.a Open garage window
5. Put key in ignition, close eyes, *pray*, Open one eye to look at oil pressure gauge, put foot on clutch, pump gas 3 times, turn engine over for 7 seconds.
6. Take in deep breath. Hold it. Pump accelerator three more times, start car.
7. Open other eye, watch oil pressure come up while waiting for blue oil haze from bad valve guide seals to clear.
8. Put on cape, making sure it can flow out through the back window.
9. Drive off to cruise night!
Old May 6, 2011 | 03:28 PM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I run a radar loop online to see if there is any rain in the area . I check the oil, the belts, and the tires and go. Drive it easy until it reaches full operating temp and then you are ready to romp
Manuel Azevedo's Avatar
Manuel Azevedo
This may sound smart assy but I don't intend it to sound that way. But there is nothing special about these cars drive train wise. They are a small or big block Chevy with transmissions weather standard or automatic that have been around for a looong time, nothing special cause it is in a Corvette body/frame. Reliability is no better or worse than any carberated Chevrolet. They are as good or bad as anyone takes care of any car. But we do love these Corvettes and they do feel special to us!! Just use common sense and all is like any other car.
Old May 6, 2011 | 05:59 PM
Alan 71's Avatar
Alan 71
Hi A L 71,
The one difference from a new car I notice is that the gas needs to be pumped twice if the car's not been run for a week.
It always starts, but for some reason I'm still thankful each time!
Regards,
Alan
Old May 6, 2011 | 06:49 PM
HOOAH's Avatar
HOOAH
1969/1971/2021 Coupes
St. Jude Donor '09-'10-'11-'12-'13-'14-'15
3.5 Curl chest hair
Hey Schaggy,
You stole my identity.
Terry
Old May 6, 2011 | 07:07 PM
gq82's Avatar
gq82
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Alan 71
Hi A L 71,
Regards,
Alan
On a 71 you should turn the key to on, pump the gas a few times then turn the key to start. This of course primes the carb but for a stock 71 it also sets the CEC solenoid.
Old May 7, 2011 | 03:00 AM
Spocc's Avatar
Spocc
as long as she has not dropped a liquid gift on the concrete, keep checking the gauges as i drive off...
Pete.
Old May 7, 2011 | 06:59 AM
7T1vette's Avatar
7T1vette
If the carb and choke are in good working order and adjusted properly, you only have to pump the throttle (to the floor) one time to start the car. If the weather is a bit cold, you may want to let the engine run on "fast idle" for 10 seconds (or so) before you tap the throttle to lower the idle speed. Then just drive it.
Old May 7, 2011 | 05:22 PM
VetteHalen's Avatar
VetteHalen
3.5 Curl chest hair
wow, that's pretty much my routine too! except, i don't open the garage window...
Old May 7, 2011 | 05:41 PM
PRNDL's Avatar
PRNDL
I spin the green wheel to connect the battery.
Put on my driving shoes... regular running shoes are too wide.
If I have been doing any work on the car check underneath to make sure I didn't leave anything lying around.
I used to pop the hood and watch it run before closing the hood and driving off, but I don't do that much any more. It if's leakin, then its leakin...
To Pre-Drive routine
Old May 7, 2011 | 07:18 PM
Double_0_7's Avatar
Double_0_7
3.5 Curl chest hair
Priceless,
Old May 7, 2011 | 08:28 PM
Paul L's Avatar
Paul L
With respect to others, and after the spring inspection (now done), I just turn the key and drive. These 350 V8s were installed in millions of family cars years ago and were daily drivers. Unless you have souped up a car they are just ordinary engines. Nothing special.
Old May 7, 2011 | 09:31 PM
trainor's Avatar
trainor
Since my engine is a fairly new build with only 3000 miles on it, I usually take a quick peak under the car for puddles!! No puddles, pump it, start it, warm it for 60 seconds and light that sucker up. Oh and meanwhile I have this big S#%t eating grin on my face. When I come home with the same look on my face my wife always says" out with the redhead again huh"? Yup the car is red. Drive em like its the last time.
