French locks
Old May 14, 2011 | 02:07 PM
kingkohlmn's Avatar
kingkohlmn
Veteran: Marine Corps
Default French locks
A friend of mine that works on vettes for a living, recommends I not use the french locks, but use lock washers. He feels you can not torque then as well as they should be. I don't plan to have the car judged ever. Looking for you thoughts.
Thanks Bill
Old May 14, 2011 | 02:21 PM
...Roger...'s Avatar
...Roger...
I've used lockwashers on most cars (non-judged)for years with no problems.
Old May 14, 2011 | 03:15 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Using lock washers will work just fine. I prefer to use the french locks but I only use the stainless steel set. The standard steel ones will twist up when you draw down the bolts while the Stainless set will not...
IMHO,
Willcox
Old May 14, 2011 | 04:38 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Back in the day, there must have been a good reason why the factory engineers thought they should be there. They could have just used lock washers.....which cost a heck of a lot less.
Old May 14, 2011 | 05:02 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
when you try and torgue down the nuts, the dang French locks, will twist up underneath the nuts, buggers them up ... and I am sure if messes with torgue down.
I agree use lock washers.
Old May 14, 2011 | 05:05 PM
7T1vette's Avatar
7T1vette
The aftermarket French locks will "wad up" when torqued. The factory pieces were hardened to prevent that from happening. I used the French locks because that was the way the car was built...but I had to put grease under the bolt heads to keep them from twisting around.
Old May 14, 2011 | 06:27 PM
...Roger...
But I wonder why they didn't just drill the bolt head and wire them like aircraft do ?
Old May 14, 2011 | 06:45 PM
Alan 71's Avatar
Alan 71
Hi,
O.K.
Here's the truth.
Every time I read or think about french locks I imagine French thighs.....
I'm ashamed to sign a post for the first time!
Regards,
Alan
Old May 14, 2011 | 07:17 PM
daanbc's Avatar
daanbc
St. Jude Donor '12
Originally Posted by Alan 71
Hi,
O.K.
Here's the truth.
Regards,
Alan
I image the "light" from FRAGILE in the xmass story. LOL.
Old May 14, 2011 | 09:02 PM
0Willcox Corvette
Former Vendor
This is why we use the Stainless Steel Locks in the shop, they don't twist up. 7t1 is right, the originals won't twist up.... the steel repro's look like a twisted train wreck when you use them.
Old May 14, 2011 | 09:04 PM
Faster Rat's Avatar
Faster Rat
Aircraft fasteners that require safety wiring are generally low or non-torque applications...small bolts and wing nuts come to mind. More of a vibration issue. Besides, airplanes can't just pull over to the side of the road when something falls off.
When you bend the tangs on the lock...that is really secure. Same thing on the large bolt holding the backing plate to the spindle.
Old May 14, 2011 | 09:14 PM
Faster Rat's Avatar
Faster Rat
Hi,
O.K.
Here's the truth.
Regards,
Alan
Every time I think about a cigar I remember hearing the best were rolled on the thighs of Cuba's most beautiful women. Makes me want to start smoking again....just for a moment.
To French locks
