Engine Bay Pics
Old Jun 15, 2011 | 10:56 PM
  #61
daanbc's Avatar
daanbc
St. Jude Donor '12
Originally Posted by palmbeachvette76
I used a chaulking gun tube of Loctite Power Grab from Home Depot. Put a bunch on the carpet of the speaker box then pressed against the under side of the rear deck. I cut a couple pieces of scrap wood to support the speakers overnight, then removed the wood the next day and it has held up just fine.
I would be afraid the loudness of the base would loosen it. I may try it, but add some kind of L shape bracket. Thanks..........
Old Jun 16, 2011 | 06:23 AM
  #62
hammadown's Avatar
hammadown
Looks Great Cajun..........
Hammadown
Old Jun 16, 2011 | 06:40 AM
  #63
palmbeachvette76's Avatar
palmbeachvette76
Good point, something I didn't think of but then again I halfway expected them to fall off but it's been well over a year. In fact if I wanted to remove them I'm not sure how I could without harming the fiberglass and paint on the outside. Maybe a wire acting as a saw the same as removing a windshield might work. Then again there only 6x9 speakers with some bass but not so much and I rarely listen to the stereo anyway, that's what big cams are for , however when the wife is riding and asks " can we turn on the radio" I use it then
Old Jun 16, 2011 | 11:28 PM
  #64
Ray Y's Avatar
Ray Y
While I don't think the originator of this thread meant for it to be a photo gallery, it seems to have turned into one.....
Either way there are some great looking transformations under hood going on here. So I guess I'll join in too...My before shot is a LS6 motor that was taken from a '71 Chevelle which was installed when I purchaesed my'70 vert 5 years ago now. The After photo is with the new motor which is a 555 cu in Dart block with Brodix aluminum heads, and of course a few other tricks up her sleeve.
BEFORE:
AFTER:
Old Jun 17, 2011 | 08:17 AM
  #65
damoroso's Avatar
damoroso
Before:
After:
Old Jun 17, 2011 | 08:54 AM
  #66
cicconjo's Avatar
cicconjo
Love it. Some incredible engines on this forum.
Old Jun 18, 2011 | 03:30 AM
  #67
jr9170's Avatar
jr9170
From: YANKEES UNIVERSE 70 454-LS5 500 ft-lbs Torque
Old Jun 18, 2011 | 03:21 PM
  #68
mtcraigco's Avatar
mtcraigco
Before
After (90% done)
Old Jun 18, 2011 | 09:01 PM
  #69
Ironman Motorsports's Avatar
Ironman Motorsports
Still a work in progress but gettin closer
Old Jun 18, 2011 | 09:47 PM
  #70
arkus's Avatar
arkus
Originally Posted by mtcraigco
Before
After (90% done)
nice engine
what are the specifications ?
Old Jun 19, 2011 | 01:31 AM
  #71
mtcraigco's Avatar
mtcraigco
Originally Posted by arkus
nice engine
Scoggin Dickey 454 HO short block, forged pistons, rods, crank
ZZ502 cam installed by them, degreed straight up
ZZ502 heads, port matched to edelbrock RPM air Gap, 1.25 intakes
Crane magnum roller rockers
Quickfuel 750 with mechanical secondaries
hooker super comps (which were a BIAAATCH to fit )
3" exhaust with 3" flowmasters
Should be an easy 550HP/550TQ at the crank
Will probably toss a 150 or 200 shot of squeeze on top, am also considering a Weiand 174 miniblower after the shake down runs are done instead of N2O, but am ready to be driving it too, so don't know if I'll tear into the top end for that or not
