63 split window
Old Jun 21, 2011 | 11:42 PM
bobs1248's Avatar
bobs1248
5th Gear
Default 63 split window
I have a 63 number matching numbers, factory air, 340 hp motor. I thought ac came on the 300 hp.
Old Jun 21, 2011 | 11:46 PM
scottyp99's Avatar
scottyp99
Well, that's interesting, but you might have better luck getting some info by posting on the C1/C2 forum.
Scott
Old Jun 22, 2011 | 09:42 AM
7T1vette's Avatar
7T1vette
I think you could order A/C with any engine that did not have solid lifters. (the problem was that the drive belt would fly off or snap at solid lifter red-line speeds)
Old Jun 22, 2011 | 12:14 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Go here. http://www.ncrs.org/ Join. The C2 gurus on the NCRS site will be able to answer all of your questions.
Noland Adams' book is worth the price. Order a copy.
Old Jun 22, 2011 | 03:29 PM
srs244's Avatar
srs244
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
a quick look at a corvette black book would also give you the info you seek. unfortunately, mine isn't with me in the office at the moment, sorry. i had a 63 way back then, but honestly don't remember to answer your question off the top of my head.
Old Jun 22, 2011 | 03:36 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by srs244
...a quick look at a corvette black book would also give you the info you seek...
Actually, it doesn't. I looked.
Black Book does not qualify C60 availability on the 63s, but does confirm only 278 factory air cars were produced.
Noland's book says C60 was not available on the L-76 and L-84.
To 63 split window
