1970 wiper door will not open
Old Jul 25, 2011 | 09:29 PM
sheldonbaker's Avatar
sheldonbaker
Default 1970 wiper door will not open
hey my wiper door will not open fast it getting hong up on the wipers .. you have to pull up on the center of the wiper door ,,, wipers and all the other stuff work ,,, is there a thing that pops the door up or what
Old Jul 26, 2011 | 02:31 AM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
first off we assume your car and vacuum system are in proper working condition..
yes a vacuum actuator opens and closes the wiper door,
that actuator is controlled by a pilot vacuum valve, it your door is slow/weak,
either the actuator is worn out, or the most likely cause is binding from the door,
and pivot/bearings and 40 years worth of crud. with the actuator dissconnected,
you should be able to move the wiper door by hand, find the actuator,
on the passanger side on the firewall.
if not working smoothly,
Dissassemble clean and lube all pivot points for the door assemble,
when everything is working good that door pops open and close real quick.
Old Jul 26, 2011 | 08:45 AM
7T1vette's Avatar
7T1vette
Has it ever worked correctly since you have owned the car? Has work been done to the wiper door and/or wiper system recently?
Old Jul 26, 2011 | 03:25 PM
Alan 71's Avatar
Alan 71
Hi sb,
Are your wipers starting before the wiper door has a chance to open completely?
There is a safety switch assembly just to the right of the distributor mounted on the fire wall. It's purpose is to delay the electrical signal to the wiper motor until the wiper door is completely open.
Perhaps your switch may need some adjustment.
Regards,
Alan
Please ignore the oval, it was for another post.
Old Jul 26, 2011 | 10:26 PM
sheldonbaker
well i will work on them this weekend i do have the door working good by hand ,, the car has never been apart the door will close right ,, just will not open right ... like it is slow to open i orded a new vacuum actuator and relay ,,, just so it had a new ones on it .. i want them to work ,,, just like the car was new,,,, not stopping intell there right ,, think thats one of the coolest thing on the car and i love the bumpers i think there the real corvette of the corvette ...
Old Jul 27, 2011 | 06:47 AM
Alan 71's Avatar
Alan 71
Hi S,
I also replied in your other thread.
I'd like to suggest that if you're going to work on your car you think about buying the AIM, (ASSEMBLY INSTRUCTION MANUAL), it was used on the production line in St. Louis; the GM 1970 CHASSIS SERVICE MANUAL, it was used at the dealership's service department; and a headlight/wiper trouble shooting guide.
If you don't have these three helpers you could well be buying parts you don't need.
Good Luck!
Regards,
Alan
Old Jul 27, 2011 | 07:58 AM
...Roger...'s Avatar
...Roger...
Originally Posted by sheldonbaker
the door will close right ,, just will not open right ... like it is slow to open,,
Probably just a leaking witches hat seal , a new actuator should fix that,a new relay can't hurt (save your old relay).
Old Jul 27, 2011 | 08:02 AM
BB72's Avatar
BB72
I beg to differ, it's a funnel.
Old Jul 27, 2011 | 09:26 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
...Probably just a leaking witches hat...
Originally Posted by BB72
...I beg to differ, it's a funnel...
One man's witch's hat is another man's funnel.
Old Jul 27, 2011 | 09:47 AM
builder's Avatar
builder
My wiper door does the opposite. Opens correctly, closes on top of the wipers before they retract. Any thoughts on that?
Old Jul 27, 2011 | 09:57 AM
Easy Mike's Avatar
Easy Mike
Essentially the same problem. Follow Alan's post.
Old Jul 27, 2011 | 10:05 AM
...Roger...
Sounds like the valve under cowl is not adjusted correctly.
Not a 68 is it ?
Old Jul 27, 2011 | 11:53 AM
builder's Avatar
builder
Not a 68 is it ?
Mine is a '69 Roger.
Old Jul 27, 2011 | 12:26 PM
...Roger...
Sounds like the valve is passing vacuum when it shouldn't be,is the 3rd hose (top hose) plugged where it comes out into the engine compartment ?
Old Jul 27, 2011 | 09:22 PM
sheldonbaker
well i bought them all just have not got them yet,.,, head lights both go up fast but only one goes back down just to throw that in with the wiper ..
Old Jul 27, 2011 | 09:28 PM
69Vett's Avatar
69Vett
make sure that vacuum wiper switch has an open vent line, lots of people plug them, because they see a vacuum line not connected to anything.
Old Jul 31, 2011 | 10:15 PM
sheldonbaker
Default well
Originally Posted by 69Vett
wellmake sure that vacuum wiper switch has an open vent line, lots of people plug them, because they see a vacuum line not connected to anything.
vent line from the wipe wall there is like 3 lines and on is not hook to a thing thats right you are telling me then
To 1970 wiper door will not open
Old Jul 31, 2011 | 10:16 PM
sheldonbaker
Default ok
the 3 coming out from the wiper switch . witch one is the vent line
Old Jul 31, 2011 | 11:28 PM
69Vett's Avatar
69Vett
1 problem at a time.
If your wipers get hung up on the door, because not fully open.
First wipers should not start until door is fully open,
this is interlocked thru the Door open switch. Adjust as needed.
Alan's picture shows the switch.
if the door fails to open all the way, either mech. binding, or bad actuator or wiper replay.
you need to test each item, not just replace.
Old Aug 1, 2011 | 09:03 PM
sheldonbaker
Default wiper door
ok here we are just put on the new relay and the new actuator too now the actuator is not ajust right i just put it on i dont know how to ajust it but this is what i got now start the car the wiper door goes up and stays up ,, and the other day i did try to mess with the one switch in the pic so what do i do now may i say my head lights work bad to the bone put new relays on them and they are fast up fast down love it
