Side Mirror
Old Aug 17, 2011 | 03:29 PM
newbie2vette's Avatar
newbie2vette
Default Side Mirror
I have a 1972 LT1, I think it is one of the "bare bone" model because it only has one side mirror but have seen others in photos having two. Has anyone added a second side mirror to their car? Is doing so degrade the value? thank you.
Old Aug 17, 2011 | 03:52 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Nothing "bare bones" about an LT-1.
Passenger's side mirror was a dealer add on. Driver's side mirror only was stock.
Old Aug 17, 2011 | 04:01 PM
ehinch19's Avatar
ehinch19
I have a 75 that the PO put the second mirror on it I don't know if it was just me but it was worthless and it didn't tilt in enough so I took it off when I repainted I think it looks better without it just my .02
Old Aug 17, 2011 | 04:12 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by ehinch19
I have a 75 that the PO put the second mirror on ...but it was worthless...
Suit yourself, but I like both mirrors. Duals on my 80; duals on the 74 I had; and I've added the RH mirror to my '68.
Old Aug 17, 2011 | 04:44 PM
Mike Ward's Avatar
Mike Ward
Must have had something wrong with the mirror or it's position. Mine works fine. I'd rather be able to see out the far side properly rather than have to worry what the car would look like after a collision with somebody in the blind spot.
A correct, matching GM mirror will have no negative effect on value.
Old Aug 17, 2011 | 06:26 PM
Mashman's Avatar
Mashman
It would be pretty easy to add the passenger side mirror yourself.
The mirror is attached to the mounting plate via a small allen screw. You can remove this screw to see the mounting plate. The mounting plate is attached to the door by 2 screws. These screws go the door skin, and attach into the door.
I would take off the drivers side mirror, and mounting plate, to see exactly how it's mounted, and what the correct location is. And then measure 20 times, before you drill. All you need to do on the passenger side, is drill 2 holes to mount the mounting plate. It's all about making sure you drill in the correct spot.
Old Aug 17, 2011 | 06:47 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
2 Mikes who have explained so much over time. I took their lead a couple years back and discovered the available pass side mirror kits have a template that makes this addition, a piece of cake.
Only requirement for a clean install: steady hand when drilling.
I put too many miles on my ride not to have that safety boundary. Blind spot, no more. The looks didn't suffer a whit, either.
Old Aug 17, 2011 | 06:51 PM
vettebuyer6369's Avatar
vettebuyer6369
I think the cars with sport mirrors have to have 2, but I don't care for the RH mirror in chrome on the early cars. They look wrong to me.
Old Aug 17, 2011 | 07:29 PM
shrekviper's Avatar
shrekviper
I put the passenger mirror on my '69 as well. The kit came w/ a template that worked great. At first it wouldn't adjust enought, but after realizing I had the mirror "upside down". The mirror should be offset away from the car so the larger side of the mirror (from the mounting ball) is outboard and up just like in Dustup7T2's pic. Nice pic btw.
I'm not planning on selling my vette so I'm not concerned w/ monetary value. I'm making my car what I want it to be. I think it looks weird with only one anyway.
Old Aug 17, 2011 | 11:11 PM
7T1vette's Avatar
7T1vette
I'm still amazed that NO ONE (that I know of, anyway) produces a convex mirror to fit into the early C3 mirror bodies. So, we are left to see very little of what's behind us on the right...or to the right of us, because we are all relegated to flat right side mirrors [unless we want to upgrade to a 'sport' mirror, that is].
What's up with that?
Old Aug 17, 2011 | 11:48 PM
redman76's Avatar
redman76
St. Jude Donor '09
Originally Posted by Dustup7T2
That is sweet!
Old Aug 18, 2011 | 03:01 AM
Clubby99's Avatar
Clubby99
Passenger side is mounted differently than driver's side. Uses well nuts similar to what is used for the luggage rack. Actually easier to install.
Old Aug 18, 2011 | 03:05 AM
arkus's Avatar
arkus
They didn't put a right side mirror on to keep the body lines clean .
I like the original look .
Old Aug 18, 2011 | 07:40 AM
newbie2vette
Thank you for the great inputs, I received the catalog I ordered which contain the kit I like. this kit include both mirrors, mounting hardware and they are the larger mirror.
Definitely will measure 1K times before any drill bit touches the car.
Dustup7T2, Nice looking ride. may I asked what style wheels you have on your? Again thank you everyone.
Old Aug 18, 2011 | 08:19 AM
BTGRN75's Avatar
BTGRN75
St. Jude Donor '11
I installed the RT. mirror from CA using their template. I was VERY careful, but it still ended up slightly lower than the driver side mirror. Not really noticeable unless you look closely, but it still bugs me. So you may want to pull the driver mirror to double check holes and HT. before you drill.
Old Aug 18, 2011 | 08:29 AM
Trae1976's Avatar
Trae1976
Easy install.
Old Aug 18, 2011 | 08:43 AM
7T1vette's Avatar
7T1vette
If you want the mirrors to be located in the same way, you will need to remove the driver's side mirror and measure the holes from the window edge and from the rear door edge. Otherwise, it will only be close.
To Side Mirror
Old Aug 18, 2011 | 12:50 PM
Dustup7T2's Avatar
Dustup7T2
Thanks n2v. They are Coy's Wheels, C-5 models with gray spokes. Here's a link with more data:
http://forums.corvetteforum.com/c3-g...-pictures.html
Post #'s 27, 41, and 43 offer answers to common questions and feel free to contact me if you have others. I'll do what I can to help.
Originally Posted by Trae1976
Easy install.
Great photo description and template is well defined. Thanks for posting.
Old Aug 18, 2011 | 01:16 PM
Mashman's Avatar
Mashman
Hmm?
I just had my passenger side mirror off to re-paint, and it didn't have any well nuts, it had longish screws that screwed directly into the metal of the door.
I see the pictures in Trae1976's post, so maybe it's the later kits that have the well nuts, and the dealer installed mirrors were done the same as the factory?
Anyway, I can see that the current kits would be much easier, since you don't really need to worry about the angle of you drilling.
Old Aug 18, 2011 | 05:45 PM
oldsarge's Avatar
oldsarge
My 73 has two mirrors and yes it is a very simple task to do yourself, great info and pics from Trae1976, easy steps to follow.
