Numbers location & retrieval
Old Oct 7, 2011 | 11:05 AM
  #101
rafalc's Avatar
rafalc
Originally Posted by BBCorv70
Otherwise it's really awkward and there's risk of dropping the pivot bolts down into the black hole..
No kidding...awkward indeed. I lost one of those white washers in the hole so now I plug it with rags/paper towels. I'm a little hesitant removing the actuator adjusting rod so I might give it another try with screwing the door on without removing the brackets. It sure doesn't help that one of the screw holes has messed up threads
This will be the 3rd day I'll be going at it, running out of patience. If can't get it, I guess I'll have to remove that third (middle) bracket. Might look for a smaller ratchet set since the one I have does not fit in that tight space very well.
UPDATED:
Let me get this straight....I can remove the 2 screws holding the actuator in place, I think I may also be able to remove the other 2 screws (circled in the pic below) without disconnecting the rod. If I can get those out, will the bracket come loose? OR do I absolutely HAVE TO disconnect the adjusting rod?
Old Oct 7, 2011 | 11:31 AM
  #102
BBCorv70's Avatar
BBCorv70
Originally Posted by rafalc
UPDATED:
You should be able to remove the nuts using an extension with your socket. Possibly use a nut driver.
Yes, if you remove the nuts from the bracket and the two nuts on either end, that will release the linkage from the firewall. You'll still need to disconnect the actuator if you plan to lift the linkage out of there. Disconnecting the actuator is no big deal, just loosen the jam nut and keep turning the sleeve until on end comes off. Reverse the procedure to reinstall. If you keep your jam nut in relatively the same position you'll have a reference as to how far to turn when reinstalling. If not, still not a big deal. The adjustment is pretty easy.
Old Oct 7, 2011 | 07:22 PM
  #103
rafalc's Avatar
rafalc
Another washer down the drain but I finally got the door back in place without removing the entire bracket assembly. Getting a nut driver extension did help and gave more room to apply some torque to the screws. Now I just have to fine tune the alignment as he edge closer to the hood is too low and the edge closer to the windshield is too high (on the driver side only).
This experience has taught me something....ONLY remove the wiper door if you absolutely have to!
