composite rear spring
Old Nov 20, 2011 | 05:42 PM
pippo350's Avatar
pippo350
I'm just thinking to install a composit spring on my'81,I have changed the original shocks with kayaba gr2.
I use the car just for a ride and I don't like the car when it's too stiff,I'm thinking to put the 300lbs.
About your experience this combo will work fine?
Thank you.
Old Nov 20, 2011 | 09:04 PM
johnmb's Avatar
johnmb
Originally Posted by paul 74
Post a pic of "stink bug".
Will do!
Old Nov 20, 2011 | 09:05 PM
johnmb's Avatar
johnmb
Originally Posted by leadfoot4
You just need to adjust the ride height, by "lengthening" the bolts at the end. If you can't get it low enough with the bolts you have, get some a little longer. (Grade 8, of course...)
I would...but then the bolt head would be below the rim.
Old Nov 21, 2011 | 01:12 AM
7T1vette's Avatar
7T1vette
The longer bolt won't stick down farther. It will allow the back end of the trailing arm to raise higher, which then will cause the front end (connected to the body) to lower.
Old Nov 21, 2011 | 07:26 AM
leadfoot4's Avatar
leadfoot4
Active Streak: 90 Days
No it won't...it's position is defined by the bushing that's at the spring, which remains constant.
Old Nov 21, 2011 | 04:24 PM
Kid Vette's Avatar
Kid Vette
You guys are kidding, right?
Old Nov 21, 2011 | 04:47 PM
Paul L's Avatar
Paul L
The end of the 10" bolt (not the head, it is up) will definitely be below the edge of the rim.
Old Nov 21, 2011 | 05:42 PM
Paul L's Avatar
Paul L
Will do!
Haven't see it.
Paul L's Avatar
Paul L
The bolt head is on top. This is the Bubba version.
An 8" bolt works fine.
I could lower the back a bit but with 235/60s it is OK for me. It would look much better with 225/70s but the tires on it are 80%. Why change?
Old Nov 21, 2011 | 06:01 PM
leadfoot4's Avatar
leadfoot4
No-o-o.......
Old Nov 21, 2011 | 06:51 PM
Paul L's Avatar
Paul L
What are we kidding about?
Old Nov 21, 2011 | 07:29 PM
kenpofan's Avatar
kenpofan
Any penalty at a show for the change on a 71 ?
Old Nov 21, 2011 | 07:37 PM
  #33
Paul L's Avatar
Paul L
Do you mean NCRS?
This thread is getting confusing. It's just a change of the rear spring!!
Old Nov 21, 2011 | 07:47 PM
  #34
kenpofan's Avatar
kenpofan
Do you mean NCRS?
Guilty of topic drift..
Dad left me a 71 .
It was in shop at his passing.
I wont to show her in the local shows.
Everybody states she is a matching #'s car..leave her alone ?
Old Nov 21, 2011 | 07:55 PM
  #35
Paul L's Avatar
Paul L
Dad left me a 71 .
Sorry to hear of your Dad's passing....Sometimes it is difficult to know what the real question is.
Yes, if you wish to present at shows as an original car leave as is. If you wish to drive then go composite.
Old Nov 21, 2011 | 08:02 PM
  #36
johnmb's Avatar
johnmb
Default I've got a day job.
Haven't see it.
Geez, I worked dark to dark... no time to play...
I did order the longer bolts however.
John
Old Nov 21, 2011 | 08:20 PM
  #37
kenpofan's Avatar
kenpofan
thanks..seems to be the call.
To composite rear spring
Old Nov 21, 2011 | 10:24 PM
  #38
Kid Vette's Avatar
Kid Vette
Wow, can't believe I have to explain this. OK, if the longer bolt doesn't stick down further in relation to the wheel; how is the car lowered? Go out and take a look at your Vette. The longer bolt allows the spring end to go down closer to the ground which lowers the car.
Old Nov 22, 2011 | 07:22 AM
  #39
leadfoot4's Avatar
leadfoot4
Old Nov 22, 2011 | 07:25 AM
  #40
leadfoot4's Avatar
leadfoot4
But in actual practice, the change in bolt lenght, if done properly, isn't that significant enough that you'll get into trouble. Keep in mind, this rear suspension design has been around since the 1963 model year, without any major ride height adjustment issues....
