U-joint caps
Old Nov 24, 2011 | 10:17 PM
Mooser's Avatar
Mooser
Default U-joint caps
I've got the replace at least 1 u-joint cap (u-bolt style) so might as well do all four
Just looking at the available u-joint caps for the diff side of the 1/2 shaft and see that they offer the u-bolt style and also a HD cap (looks like a miniature crank shaft bearing cap)
Any opinions / comments?? on these HD ones? will they fit? Overkill? Solution to a problem that never existed?
Mooser
Old Nov 25, 2011 | 08:15 AM
markids77's Avatar
markids77
HD yokes are different than standard so you cannot interchange parts. Unless you opt to swap yokes you're stuck with u-bolts.
Old Nov 25, 2011 | 09:42 AM
BKbroiler's Avatar
BKbroiler
I used the HD billet caps from Drag Vette on the diff side on my 77. Not sure if its overkill, but I do abuse mine severely.
Old Nov 25, 2011 | 01:29 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
The HD yokes have threaded holes to accept the cap bolts, while the standard yokes have unthreaded holes for the u-bolts to pass through.
Old Nov 26, 2011 | 11:36 AM
Mooser's Avatar
Mooser
Now that make total sense, thanks
Mooser
Old Nov 29, 2011 | 05:32 PM
ratbike88's Avatar
ratbike88
Default What about HD caps with standard yokes?
Any thoughts on this setup? HD caps, standard yokes, grade 8 bolts.
To U-joint caps
