first corvette as a driver
http://forums.amceaglenest.com/index.php?topic=15595.0
Wow Priya - that is awesome - nicely done
Hi. I'm in pa. My Vette is a 72. I went with a vanity plate..which requires annual safety inspection. Car is exempt from emissions. The antique plates do not require an annual inspection. With a car that is 38 years old my advice is to get the annual inspection. It is a safety issue. Leaking gas lines, loose bolts, cracked seams, bad tires, old hoses etc... Anyone of these could cause an emergency while driving and put you, the car and other drivers at risk so I suggest that no matter which plate you choose, inspect it annually.
Now with respect to a c3 as a dd for PA, the answer is no. It's not a good idea at any level. If you lived in Tampa or San Diego etc the answer would be why not. The road conditions from Jan to Apr with all the salt,rocks and snow, slush,ice etc are not conducive to operating a lightweight, fiberglass vehicle with any consistent reliability. On clear, dry, above freezing days ...sure, if you need to...but I wouldn't do it. I own four vehicles. I drive all of them. I drive the Vette only in the best conditions and even then it's a gamble.
My advice. If you can acquire the Vette as a 2nd car; not rely on it as your mode of transportation to work; have a garage for it (to protect from theft, vandalism, and weather; and if you have some savings/ disposable income that would enable you to spend $500 to $1500 on the Vette should something happen..then do it.
Other opinions may vary, which is fine.. But I know this is solid advice.
Best of luck in whatever you decide to do.
I drive mine in sun, rain or snow. Of course it's not as pretty as yours, which is actually kind of a benefit because I don't worry about the paint getting messed up
I drive to work and back (80 mile round trip) a few times every month. A stock 350 in good shape, I've come to find out, is pretty darn reliable.
Enjoy your car!
He already bought one. Also he stated that he has another vehicle.
